Help with camber and toe
Old Aug 5, 2008 | 05:07 PM
lifeguardandy's Avatar
lifeguardandy
Default Help with camber and toe
I hit a curb going 30 mph on the passenger side which messed up the rear lower control arm and maybe the spring bucket also and caused a lot of toe out. I replaced the lower control arm and its still got some toe out which makes the car feel very light in the rear. I also tried adjusting the toe and camber bolts and it helped some but theres still some toe out, even though the toe is set to its max. Is there something else I should be looking at? I checked the subframe and it looks fine, I will be replacing the spring bucket tomorrow to see if that helps too. the spring bucket and the additional arm that is next to the lower control arm is not visibly bent although im going to change them. the car also makes a screetching noise at 45 mph. is there anything else i can do, Any suggestions would be awesome.
THANKS!
Old Aug 6, 2008 | 07:33 AM
Tim@WestCovinaNissan's Avatar
Replace both of those parts and if it is still off then you might have to replace the knuckle. If you have to replace the knuckle make sure you get a new hub and bearing as well.
HoBrahYouStink
Jun 24, 2016 10:58 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
Rowlett
Misc.
Oct 2, 2015 10:38 AM
