How hard is it to install metal A/C line?
Old Aug 7, 2008 | 02:32 PM
SuperBlack350z's Avatar
SuperBlack350z
Default How hard is it to install metal A/C line?
seems that my cold air intake has rubbed a hole through the high side AC pressure line. I have access to all of the freon stuff here at work. So i'm guessing i will evacuate the freon.
Is it hard removing and installing the new line? Any special tools? Any help would be great. Thanks.
Old Aug 7, 2008 | 07:22 PM
SuperBlack350z
bump
Old Aug 7, 2008 | 07:28 PM
Barzten1's Avatar
Barzten1
Just realized I have a hole in mine. Subscribed
Old Aug 7, 2008 | 07:32 PM
SuperBlack350z
lol. I actually aluminum welded it and everything was fine until it was leaking again. 300 psi of air will do that though.
Old Aug 8, 2008 | 08:43 AM
HondaKiller's Avatar
HondaKiller
my injen has eaten about half way through the metal line on mine also, subscribed.
Old Aug 8, 2008 | 08:49 AM
SuperBlack350z
i just picked up the hard ac line with the orings or whatever from Nissan. It cost about 190 but with my dealer discount, came to about 150 bucks. Which sucks btw..lol.
I'll do the install tomorrow and hopefully everything will go fine. I believe i will need a special AC line removal tool. Thank God i have free access to the freon machine and free freon. This ordeal would of cost me around 4-500 if i gave it to the dealers.
Old Aug 8, 2008 | 08:50 AM
Ed 718's Avatar
Ed 718
BRAVEHEART
I just had a shop fix mine but it did not look to hard to do.
Old Aug 8, 2008 | 08:55 AM
VO...'s Avatar
VO...
Administrator
VO(remembers to check his AC line after work today)
Old Aug 8, 2008 | 09:08 AM
SuperBlack350z
my hole was a size smaller than a pin hole. It's VERY small. I had to evac my whole system and then put freon back in it just to see where the leak is. Even with a tiny hole, the freon/dye comes out fast because of all the pressure. So some of you may have a small leak where the AC doesn't work as good but still blows out somewhat cool air. I quick fix of this is to put high temp rubber hose around the AC hard line between the intake pipe and the hardline. I learned the hardway through. This is on my blue roadster btw, my black Z is fine....thank God.
Old Aug 8, 2008 | 10:17 AM
SuperBlack350z
actually they billed me 50 bucks for the hardline. I'm pretty damn happy. I guess it was the wrong part from the pic, i went back up there and got it straightened out.
Old Aug 8, 2008 | 10:21 AM
ny garbage_juice's Avatar
ny garbage_juice
yuuuuuuup my injen just did the same and now i have no AC in middle of summer.
<----------suscribed for info
Old Aug 8, 2008 | 10:23 AM
blasian's Avatar
blasian
I just simply wouldn't use a CAI and get a good SRI instead
Old Aug 8, 2008 | 10:32 AM
SuperBlack350z
these are caused by SRI as well. The one on my roadster is from the injen SRI. The one on my black Z , i use the HKS intake which is an SRI and had early signs of it but i caught it before it happened.
Old Aug 8, 2008 | 10:35 AM
blasian's Avatar
blasian
Now that I think about it... I gave my friend the Injen intake and he used it for a SRI. It rubbed against the line so he made a rubber piece to secure the intake pipe and raise it a little higher to keep it away from the line.
Old Aug 8, 2008 | 10:53 AM
Ed 718's Avatar
Ed 718
BRAVEHEART
Have you guys used some heat wrap like the DEI stuff on the A/C lines?
Old Aug 9, 2008 | 05:37 PM
skippyzme's Avatar
skippyzme
Same here. Injen intake rubbed a hole in my high pressure line. Is the only option to have the line replaced? I dont much about a/c. Can I just weld it shut and have the system recharged?
Old Aug 9, 2008 | 07:43 PM
SuperBlack350z
You can weld if you want. You have to buy a braze or a aluminum type rod and weld that on. The thing is, you need to evacuate your whole system properly with a machine because when you are torching the aluminum line, if the left over freon is in there, it will be toxic. So it's a bit dangerous.
Better way is just to replace the line. I wish nissan made the line shorter or in different parts because that high pressure line is one long *** line. It goes from the front AC condensor to the back of the firewall. You will have to take off the windshield cowl, etc.
Old Aug 9, 2008 | 11:31 PM
Sorry but its a common problem for long intakes: one where the filter is behind the front bumper.
I wish it was a more popular subject so that members would take protective steps like putting a piece of rubber tubing around the air conditioning line.
Old Aug 10, 2008 | 07:24 PM
skippyzme's Avatar
skippyzme
Well I made sure the freon was out and welded it. Now do I just take it anywhere that will recharge the system or is there another step I have to take? I need my A/C. August r hot.
Old Aug 10, 2008 | 07:43 PM
SuperBlack350z
yeah, take the car in and they will do a leak test on the system just to make sure. There is a lot of pressure in the line so the weld can break or leak again very quickly.
