Stalling? Possibly limp mode?
Old Aug 18, 2008 | 07:12 PM
whiskeycheeks's Avatar
whiskeycheeks
Default Stalling? Possibly limp mode?
So the other day my cruise control started blipping on and off on me, and sometimes would not even come back on. The next day I started driving a lil fast and my cars speed felt like it was cut in half and sometimes having a "rev limiter" at 2500 4400 and 5500, It also bogged down throughout the rpm range. I did both ecu reset methods via pedal, and disconnected negative terminal several times. It did nothing, I brought it to a nissan technician, he said it was the throttle body positioning, he said he fixed that, but it is still doing it. He also said it pulled a code on the post cat 02 sensor passenger side. Could that 02 sensor be causing the studdering? Also what could be causing the blip in the cruise?
P.s. It smells like unburnt fuel sometimes so could this be running rich and causing the problem?
03 touring 350z 94,445 miles
Strup headers random tech hfcs borla catback
Any help would be greatly appreciated!!! The o2 sensor is on order for thursday so I will update then if that solves the studdering....
Old Aug 18, 2008 | 07:39 PM
whiskeycheeks
Could use some input!
Old Aug 20, 2008 | 04:46 AM
whiskeycheeks
bump..
Old Aug 20, 2008 | 06:06 PM
whiskeycheeks
bump..
Old Aug 30, 2008 | 10:19 PM
whiskeycheeks
changed the 02 that was messing up, and replaced the mafs because it was pulling a code changed spark plugs belts and oil and ITS STILL bogging down?!?!!
Old Aug 31, 2008 | 11:27 AM
mospec1's Avatar
mospec1
Im having the same problem on my 03 350Z but it goes away after I drive it for few minutes until it reaches a certain operating temp!! Its also burning ignition coils. I did not figure it out what causing the problem!! but if anyone has any ideas let me know .
MO
Old Sep 2, 2008 | 06:49 PM
whiskeycheeks
Yea until operating temp, it does it. But it will still do it randomly during normal operating tempature!
Bump!
Old Sep 4, 2008 | 09:14 PM
mospec1's Avatar
mospec1
I was told a grounding kit might help to resolve the problem! would it?
Old Sep 4, 2008 | 09:24 PM
surfcity40's Avatar
surfcity40
okay now you've crossed the line.
Old Sep 5, 2008 | 12:32 PM
mospec1's Avatar
mospec1
What line?? if you got any idea to resolve this problem I would listen!!
Old Sep 7, 2008 | 04:11 AM
mospec1's Avatar
mospec1
I guess no one can shed any light on this ??
Old Sep 9, 2008 | 06:54 PM
whiskeycheeks
mine has a grounding kit... i think its the throttle body i was told it is only opening up 83% its going back to the dealership soon... something to do with tb sensor
Old Sep 10, 2008 | 06:17 AM
chromesilverz's Avatar
chromesilverz
Take it to a professional. You have probably spent more money on it changing out parts that are good.
That being said, it might be a bad throttle body. Courtesy Nissan sells the part for $140 with core exchange. Go look at the video on how to clean the throttle body to find out how to change it out. Or better yet pay someone to do it to end the suffering.
sherm
Apr 11, 2020 05:21 PM
_bit
Oct 2, 2015 07:49 AM
Tochigi_236
Sep 27, 2015 03:40 PM
