HELP!:Interior Lights Don't Work
Old Aug 25, 2008 | 07:01 PM
350mexZcan's Avatar
350mexZcan
Default HELP!:Interior Lights Don't Work
I ran a search on here....maybe I am not looking hard enough. Anyways, My 2003 350z's Dome lights are not working. I did the due diligence on checking all fuses and bulbs.I even checked the current with a meter on the little assembly that the bulbs go in. My vanity lights( the ones in the sun visors) are out as well. Has anyone had this problem before? If so, some advice would absolutely be appriciated. I do have power going to the rear hatch cargo light.( which is strange because they are both on the same fuse according to fuse panel diagram.) My closest guess is that there is something between the door sensor and dome light that has shortet out, and that somehow the vanity lights get there power from the dome light harness to save on wiring.
Old Aug 25, 2008 | 07:35 PM
VO...'s Avatar
VO...
Administrator
Moved...
WTX350Z's Avatar
WTX350Z
chase the wiring from the light returning down to the fuse panel.
10 bucks says its cut...you bought used?
My thought is if the fuse has power (and isn't blown) and the light plug doesn't there's interference between them.
maybe someone cut the wire to power a radar detector, or the DLR installed a new mirror (incorrectly)
Old Aug 26, 2008 | 03:43 AM
projektZ's Avatar
projektZ
I'm having the same problem on my '03 the lights worked when I first bought the car (got it used a few months ago) and one day they just stoppped working. I've checked the fuses and bought new dome lights and still not working. Same as OP the hatch light works but nothing else.
Old Aug 26, 2008 | 04:07 PM
350mexZcan's Avatar
350mexZcan
Wierd.....huh? I guess I am going to have to access the headliner and do a total wire trace. If I can't get it to work I am going to do some "creative" aftermarket wiring and replace and add LED's to everything on the inside. Thanks for moving the post VO.(my bad)
Old Aug 26, 2008 | 05:23 PM
seekndestroy19's Avatar
seekndestroy19
there was a TSB for Interior Courtesy Lamps Inoperative. Only for the 2003's though. TSB #03-001
Old Aug 26, 2008 | 09:20 PM
350z2k3's Avatar
350z2k3
I had this problem on my 03. Just disconnect the negative terminal on the battery and they should work again. if not it's a control module that needs replacing. See the above TSB.
Old Aug 26, 2008 | 10:28 PM
spdtckts's Avatar
spdtckts
my 2003 was doing the same. i just replaced my battery and started working again. im assuming its the same concept as 2k3 said just disconnect the negative and reconnect.
Old Aug 27, 2008 | 06:15 AM
projektZ's Avatar
projektZ
thank you for the replies! I will check that out when I get off work.
Old Aug 28, 2008 | 01:47 PM
projektZ's Avatar
projektZ
Tried disconnecting the neg and reconnecting it. still doesnt work
Old Aug 30, 2008 | 05:19 PM
350mexZcan's Avatar
350mexZcan
I got them to WORK!!! Interestingly enough I happend upon the cure while installing my kill switch for my air bag. By the way that is a scary procedure. I did not realize that there was ANOTHER dang fuse block adacent to the battery...not the one in front of it..but, a whole other block. whats that all about? anyway, I saw that the wire connections were kinda wobbly so I titent them up. I also disconnected the power cable to run my amp wire today as well. All I know is that they work now and that is good enough for me. G-luck to all those that have this issue...IM CURED!....for now.
Old Sep 2, 2008 | 05:58 AM
ZKansasZ's Avatar
ZKansasZ
I am glad you found your problem.
But where is the other fuse box that you found?
I only saw 2 fuse boxes, one is next to my foot rest and 1 is in front of the battery.
Miguel Albanez
Oct 17, 2022 10:13 AM
etkms
Jun 19, 2022 06:30 PM
bcoffee20
Nov 19, 2015 06:39 PM
Vigman
Nov 17, 2015 04:34 AM
Shane86
Sep 17, 2015 05:33 PM
