Slow window operation
I have a 2004 roadster with 12,000 miles on it. Since new, the driver side window has always operated a little slower than the passenger side window. After reading about how weak the window motors are. I was wondering if there is anything I could lubricate on the window mechanism in order to take some strain off of the window motor.
I have a few automotive tools and could probably take the door panel off if required. Thanks, Jennifer.
You should be able to lube it. I'm not sure what you would use, but I used to have a Celica that was constantly getting bogged down. I had the dealer lube it about 3 times and it was always fine after that (for awhile anyway). I'm not sure if you'd use a Lithium grease or not. You might check with the dealer to see what they would use.
Boots patrol
Exterior
Nov 7, 2015 12:26 PM
