Possible Fuel Injector/Timing/Air Fuel Problem!!
Old Oct 14, 2008 | 11:36 PM
lenakance4life's Avatar
lenakance4life
Default Possible Fuel Injector/Timing/Air Fuel Problem!!
Hi Everyone!
I'm in dire need of help from you guys so any input is greatly appreciated.
My 350z recently brought up the service engine soon light. Something that i have notice different on the car is its idle. The rpm at idle drops to an almost stall level and pushes back up like its not getting enough fuel or something. Would anyone know what the problem might be from?
I had greddy evo tt exhaust installed and about a week ago I installed JWT pop chargers. Do you think the dealer will give me a problem due to the modifications if I take it back to them to fix?
Thnx in advance for the feedback!!!
Vahe
Old Oct 15, 2008 | 03:02 AM
Jarred@Z1's Avatar
Jarred@Z1
Z1 Motorsports
sounds like idle air volume learn problem. Dealership should fix it free its really easy.
Old Oct 15, 2008 | 04:59 AM
str8dum1's Avatar
str8dum1
yes, the dealer will give you problems and say its your aftermarket parts, as that prroblem can be directly related to the stuff you changed.
have you put back your stock parts and seen if the problem goes away?
have you done a ECU reset since you did the install?
Old Oct 16, 2008 | 01:05 AM
lenakance4life
I haven't done any of these. Do you think a reset will fix the issue?
Old Oct 16, 2008 | 08:42 PM
ladyzed's Avatar
ladyzed
It's easy to do, I've done it myself a few times. Look up technosquare's website and search for the relearn / reset procedure.
D
Uriyo_
Sep 8, 2021 08:46 AM
