Post here only if you have had your TRANNY replaced.
Old Mar 27, 2006 | 01:41 PM
  #761
alpine's Avatar
alpine
Default I just wanted you guys to know...
That there is some kind of hope out there because my tranny, after being replaced 25K and over a year ago, is still going strong.
And I am flogging it daily.
Has there been any official word as to WHY this is happening in the first place? I remember somewhere in this thread I actually posted the various things I had heard from various "official" sources, but it's been a while.
lemme know.
Old Mar 28, 2006 | 03:05 PM
  #762
showstoppertk's Avatar
showstoppertk
so then just gave me my Z back and here's what I got:
30210-CD020 COVER ASSY
30502-69F10 BEARING REH01AA R&I MT ASSY
30100-CD019 DISC ASSY
32010-CD008 TRANS
the new trans doesn't feel all that different from the last. the feel is still somewhat clunky, not much smoother than the previous.
Old Mar 28, 2006 | 04:36 PM
  #763
alpine's Avatar
alpine
If it doesn't feel any better than it did before, then it's not gonna be any better than it was before.
So far I do believe the common experience here is when they replace it, and do it right, there is a significant difference in the way it feels....
There are plenty of owners out there that have been through replacing the trans and whatever else their doing, 2, 3, and more times....
Start complaining now, so that when something comes up in 5,10,15K it's not "oh sure, now you have a problem" and written off...
good luck!
Old Mar 30, 2006 | 11:32 AM
  #764
___DJK___'s Avatar
___DJK___
Just had my tranny replaced in my 2004. Was intermittently grinding 2nd, sometimes third, and would lock me out of 3rd and 6th sometimes. New tranny (009) shifts smooth so far!
Old Mar 30, 2006 | 10:28 PM
  #765
tnk210's Avatar
tnk210
Would a 2003 with 34K miles be past the safe zone for needing the tranny replaced? The current owner has never had a problem with it. Also, is there a certain Vin # cutoff for when they fixed the problem?
Sorry for the newb questions, 39 pages is ALOT to read
Old Mar 31, 2006 | 03:37 AM
  #766
Huckingfellers's Avatar
Huckingfellers
what problems are you having with it? It all depends on the warranty you have on the car.
Old Mar 31, 2006 | 05:09 AM
  #767
tnk210's Avatar
tnk210
The car is having no problems, I'm just trying to find it if the car would be free from the tranny problems at this point.
Old Mar 31, 2006 | 11:42 AM
  #768
showstoppertk
theres no such thing. there are a lot of 03 owners who are around your mileage who are only now experiencing their first trans issues as well as guys who got up to 50k and then starting having problems. I wouldn't consider yourself immuned from the problems yet. however if you want to try to avoid the problems I'd suggest changing out the trans oil for some good synthetic.
Old Mar 31, 2006 | 12:33 PM
  #769
tnk210's Avatar
tnk210
Thanks, that helps alot. Good thing too, the tranny has Redline synthetic in it
Old Mar 31, 2006 | 02:25 PM
  #770
Huckingfellers
Keep a good eye on it. My 04 had the tranny and pressure plate swapped out. AS well as the rear outer axel joints. Drive it hard and make sure your shifting is good and see if it grinds or locks you out of gears you have a problem. Mine would grind the hell out of 2nd when shifting from high rpms no matter how perfect I shifted it. It would also sometimes lock me out of 6th gear or make me try a couple times to get into it.
I also had my front tires replaced for free as well as an alignment adjustment due to an alignment problem.
I also put sytnthetic fluid in mine.
Old Apr 3, 2006 | 07:17 PM
  #771
kracka99's Avatar
kracka99
Has the tranny problem been resolved in the 05's?
-k99
Old Apr 3, 2006 | 07:21 PM
  #772
Huckingfellers
I was wondering that myself.
Old Apr 4, 2006 | 01:22 PM
  #773
zman2's Avatar
zman2
-k99
No - it hasn't.
Just had 2006 transmission installed on my 2005 Z.
So far - so good.
Yes, there is a 009 part # transmission.
Old Apr 10, 2006 | 02:32 PM
  #774
Borla350's Avatar
Borla350
Ive got an 04 with no grind but oing into second and third it feels like metal on metal contact. Im planning on mentioning something next time I get my oil changed. Is this the usual precursor to trans problems? I take it easy on the trans so hopefully it will come out before the warrenty is up. Only have 10,000 miles on it so im a little worried. thanks, for any help.
Old Apr 15, 2006 | 10:28 AM
  #775
nesh216's Avatar
nesh216
zman2 - how many miles did your 2005 Z have on it when you got the tranny replaced and did you have any problems w/ the dealership?
I took my 2005 Z in today b/c when shifting from 1-2 it was making a thud (semi-grind) sound. Basically it sounds like it's coming from directly under the shifter and 1-2 is not as "smooth" as all the other shifts. There has also been times when downshifting to 2 and it was locked out.
Anyway the dealership (not the one I bought it from) called and said they couldn't find anything wrong w/ it.
Do you think I am alittle paranoid about the tranny? I know it's pretty notchy but 1-2 is a lot "notchier" than the rest and even sounds diff? When I dropped it off the service manager even said "it's probably the transmission". Over the phone he said that it's still under warranty (11750 k) and this tranny will be covered for another 50 k or so.
Did many ppl have to make multiple trips to get the tranny replaced?
Update: just got the car back. He said that if the tranny is going to go it will be around 20k so he told me to keep an eye on it.
Also did you know it cost $140 to get a key made!!
Old Apr 16, 2006 | 09:49 AM
  #776
zman2's Avatar
zman2
Default Replaced transmission
11500 miles when replaced.
It was grinding going into fifth and hard to get into third when rpm's were high.
No problem getting it replaced except they needed permission from Nissan because of my APS TT.
Transmissions are covered for 60,000 miles.
Good luck.
Old Apr 18, 2006 | 01:04 PM
  #777
manny007's Avatar
manny007
Tranny replaced at 50,000 miles no questions asked ( 3rd gear syncro went bad, grind everytime I threw it into 3rd)
Old Apr 26, 2006 | 03:22 PM
  #778
TTRANK's Avatar
TTRANK
I see that mcduck and zman2 had theirs replaced with a S/C/TT. Has anyone else been able to get their dealership to do it when they have FI on their cars?
My 04G sedan just went in yesterday for 2nd and 5th grinding and I have the Stillen S/C so I am afraid they are going to fight me on it even though the synchros have nothing to do with how much it...
Old Apr 26, 2006 | 06:24 PM
  #779
ABL 2 FLY's Avatar
ABL 2 FLY
Had my tranny replaced with 16,500 miles. No questions...Replacing my brothers this week. Member ID: Ktaylor
Old Apr 26, 2006 | 06:55 PM
  #780
Sullyz's Avatar
Sullyz
Question '06 Tranny Problem
Hi, I just brought my '06 DB base into shop again this week. I had a shifting problem since 250 miles. They told me to get past the 1200 mile break-in period. I have 2000 miles and when we shift from 3rd to 4th it seems sticky, hard to engage. Does not happen all the time. They looked at the tranny and they are requesting a new tranny from Nissan. I'll wait to see if they replace with a "new" or try to repair. Anyone else with a similar problem. Should I expect a "New" tranny? I think I should!!! Albany Nissan, Albany NY. SullyZ
