how to change clutch fluid
is there any good DIY out there? i'm gona do the coolant fuild, brake fluid and power steering fluid change this coming holiday time.....but looking to get the clutch fuild change as well, but dont know how to do it.........any input will really appreciated.
tks,
tks,
https://my350z.com/forum/attachments...clutch-fsm.jpg
It is from the Nissan Factory Service Manual, hope this helps.
CLUTCH FLUID PFP:00017
Bleeding ACS004N1
CAUTION:
Monitor fluid level in the reservoir tank to make sure it does not empty.
Do not spill clutch fluid onto painted surfaces. If it spills, wipe up immediately and wash the
affected area with water.
NOTE:
Do not use a vacuum assist or any other type of power bleeder on this system. Use of a vacuum assist or
power bleeder will not purge all the air from the system.
1. Fill the master cylinder reservoir tank with new clutch fluid.
2. Connect a transparent vinyl hose to the air bleeder.
3. Depress the clutch pedal quickly and fully a few times and hold
it.
4. With clutch pedal depressed, open air bleeder to release air.
5. Close air bleeder.
6. Release clutch pedal and wait for 5 seconds.
7. Repeat steps 3 to 6 until no bubbles can be observed in the
brake fluid.
8. Tighten air bleeder to the specified torque. Refer to CL-11
Bleeding ACS004N1
CAUTION:
NOTE:
it.
brake fluid.
