TPMS problem (not sensors)
Old Nov 24, 2008 | 08:44 AM
350z 6spd's Avatar
350z 6spd
Default TPMS problem (not sensors)
I have an 03 touring and the tpms light has been on for sometime. I called up my local dealer (wish I had a damn consult) and the service advisor was nice enough to go grab the consult and try to reprogram the sensors. The fronts would not program. Now, the fronts are new sensors b/c the old ones were dead. I thought that this may be the problem, however, we then told the cars computer that the rears were the fronts and the fronts still didnt register . He said it could be the bcm, but wouldn't it be the tpms computer? Has anyone had experience with this type of problem?
thanks
Old Nov 24, 2008 | 09:04 AM
Tim@WestCovinaNissan's Avatar
The BCM is the TPMS computer. Did you use brand new sensors when you replaced the two?
Old Nov 24, 2008 | 03:31 PM
350z 6spd's Avatar
350z 6spd
yup, brand new. If the BCM is the TPMS computer, what is the part that is on courtesy's parts diagram that is the tire press. control unit?
Old Nov 24, 2008 | 05:15 PM
Probably labeled as "Body Control Unit/Module"
Old Nov 24, 2008 | 05:30 PM
350z 6spd's Avatar
350z 6spd
It is labeled tire press. control unit and there is another part that is the BCM. The tpms control unit looks to be behind the driver side dash. I believe the BCM is in the passenger footwell above the ECU, Is this correct?
Uriyo_
Sep 8, 2021 08:46 AM
TDPrank
Sep 28, 2015 06:29 AM
