omg help :)
Old Jan 2, 2009 | 10:37 AM
MyIS300's Avatar
MyIS300
Default omg help :)
Hi,
I own a 2005zr touring and recently swapped out my stock wheels with 20" axis 7 mod's (used) the tires are weird config being that they are all the same for all 4 wheels 255/35/20
setup
Front
Offset: et37
Tire: 255/35/20
Rear
Offset: +38et
Tire: 255/35/20
I don't have brembo breaks, when i installed the front wheels i notice a extra bolt that I eventually removed to get my wheels to fit. I have no idea what this is...
Any ways, i put all 4 wheels on the car, made sure all tires are 35psi
when i drive now every once in a while i will see a "!" exclamation mark light up on my dash... any help would be appreciated
Old Jan 2, 2009 | 11:09 AM
EE Z's Avatar
EE Z
the bolt is so you don't put rear tires on the front
Old Jan 2, 2009 | 05:31 PM
Tim@WestCovinaNissan's Avatar
Either your new wheels don't have the tire pressure sensors in them and if they do they need to be calibrated!
Old Jan 2, 2009 | 07:24 PM
MyIS300's Avatar
MyIS300
would this light go off because i did not transfer the tps sensors from my old to new wheels?
btw I didn't do this..
Old Jan 2, 2009 | 07:32 PM
What does your manual say about “!” ?
Old Jan 2, 2009 | 07:34 PM
Yes. The sending units are in the original wheels. Without the sending units TPMS does not work.
zand02max
Videos
Oct 20, 2004 03:03 AM
missy1101
Jun 11, 2003 06:06 PM
phattyaltnatl
Aug 18, 2002 11:42 PM
