RPM drop to zero when shifting to neutral
Old Jan 12, 2009 | 11:18 PM
tomei_p's Avatar
tomei_p
Default RPM drop to zero when shifting to neutral
Hi,
i need some advice here cause sometimes (not always), (especially when the engine is hot) when i shift from any gear to neutral sometimes the rpm drop but come to normal, but sometimes it looks like the needle on the rpm meter struggles for milliseconds to achieve the normal rpm, and if it doesn't achieve that the engine turns off. What would that be?i have read many threads here but i haven't come to a conclusion. I have jwt intake, 5/16 plenum spacer, 272 tomei camshafts and haltech ecu. Would these affect that?or could it be the throttle body?
Any advice would be appreciated
Thanks
Old Jan 13, 2009 | 01:15 AM
KenTuckyZ's Avatar
KenTuckyZ
Check your timing.
Old Jan 13, 2009 | 08:10 AM
frankie945's Avatar
frankie945
Do you have a lighter flywheel that would cause that problem. Up the idle is a easy fix. But it may be the haltech it self.
Old Jan 18, 2009 | 11:38 PM
tomei_p's Avatar
tomei_p
i went to the dealer one more time and they fixed the problem finally after one more attempt..they fixed it with the use of the tester...
apex locator
Jul 23, 2021 02:27 AM
sherm
Apr 11, 2020 05:21 PM
3vilbunny
Jul 18, 2017 05:10 PM
