Window smoking
Old Feb 15, 2009 | 11:26 PM
soshiv's Avatar
soshiv
Default Window smoking
Started my car today, and did not touch the window switch but my window lowered about 1". When I went to try to roll it back up nothing happened but i saw some smoke come from where the window and door panel meet. I waited a minute and tried again and the window started to slowly (about 1/4" at a time) "jump" back up and when it reached the top it automatically lowered back to 1". I turned the car off and went inside to get something and when I came back out everything was back to normal (window normally rolled back up and down). What exactly could this have been? Should I be concerned?
Old Feb 15, 2009 | 11:53 PM
AstroZombie's Avatar
AstroZombie
No need to be concerned, smoke coming out of your door is perfectly normal!
I would say the motor is gummed up and needs to be cleaned or replaced. I'm sure you dont want to watch your Z burn right??? Might want to address this issue ASAP.
heres the sticky link on cleaning the window motor... Good luck!
https://my350z.com/forum/maintenance...dow-motor.html
Old Feb 16, 2009 | 03:20 AM
albinobob's Avatar
albinobob
You let the smoke out man now it's broken replace your motor and inspect the wiring.
Old Feb 16, 2009 | 06:09 AM
3-fifty-WeEe's Avatar
3-fifty-WeEe
a window motor new costs 480 from the dealer. id say get a re conditioned one for half that price and try it out. The install is a mild job, i did both my drive and passenger motors, the main thing is remembering where all the bolts go and what sequence, you should figure it out if you have a decent mechanical background
Siqcology
Sep 18, 2019 01:45 PM
Boots patrol
Exterior
Nov 7, 2015 12:26 PM
Sleeper_Z
Sep 30, 2015 10:25 AM
AP350z223
Sep 8, 2015 04:38 PM
