homelink garage door opener failed
Old Sep 6, 2003 | 02:01 PM
chaz's Avatar
chaz
Angry homelink garage door opener failed
I come home yesterday unable to open my garage door. Fortunately my wife was home, or I'd have been locked out!
the homelink in her car still works, as do the hand held remotes... so it's just my car. I go to reset my homelink (I have rolling code door opener) and It keeps blinking like it learned my code at step 4 (rapidly flashing)
has this happened to anyone else? hopefully I can just get the mirror replaced.
Old Sep 6, 2003 | 08:48 PM
Fresh's Avatar
Fresh
never had a garage opener, cant help ya.. *bump* for someone that can help this guy out
Old Sep 6, 2003 | 10:15 PM
ssawa's Avatar
ssawa
tried twice to program it. worked a little then stopped working, so i gave up. may try it again. it's supposed to work, right?
Old Sep 6, 2003 | 10:53 PM
jgraeb01's Avatar
jgraeb01
I've used Homelink in the past ... 3 years or so, no problems. My current car doesn't have Homelink though ... I was looking forward to the option in the Z.
Old Sep 7, 2003 | 03:50 AM
FairladyZ's Avatar
FairladyZ
Both of mine are acting up my dad and I cant figure it out. We have one to open the gate, and the other for the garage. The hand helds work, and the homelink in the envoy works. What happens in ours is that we program the buttons, but after a day or so one button opens both the gate and garage.?. This happens in both Z's.
My dad doesnt think the problem is in the homelink, yet. We are gonna try and figure it out one more time. How did you program yours?
Old Sep 7, 2003 | 07:49 AM
wld350z's Avatar
wld350z
mine has the same problem it has problems doesent work above 82 deg
check the temp in the car if this helps
Old Sep 7, 2003 | 08:02 AM
Zeelicious's Avatar
Zeelicious
I just programed mine yesterday,it opened & closed a couple of times without any problems.(I also have that rolling code)
I would erase the memory in the car home link unit and start over again. And if that doesn't work turn the garage door unit off for a minute and then turn it on again.
Old Sep 7, 2003 | 08:13 AM
6MTHavok's Avatar
6MTHavok
I think it's just the signal from this particular homelink unit (in the rear-view mirror) is poorly designed. The homelink in my old lexus worked every time.
I have a g-35 coupe, but it's the same homelink mirror. What I have to do is i'll just hold down the button the entire time I'm rolling up to my garage. Probably about 10 feet. I've had it happen where it doesn't open, where I had to get out and punch in my code. It kinda sucks, but mine works ~90% of the time.
p.s. I'm in south florida, and usually when I use it it's 90+ degrees and it works.
Old Sep 7, 2003 | 10:59 AM
wld350z's Avatar
wld350z
mine worked over 100 degs but now not over 82 degs
Old Sep 7, 2003 | 04:24 PM
FairladyZ's Avatar
FairladyZ
We follow the instructions in the manual and it doesnt work. We actually have to use a sparate switch to make the link work. How did you guys program yours? any steps we can follow?
Old Sep 7, 2003 | 05:52 PM
ragster's Avatar
ragster
If your system uses a rolling code you need to place your opener into training mode. There is a button - usually on the back of the motor unit mounted in the garage ceiling. You then have a short time to press your honelink button several times to blink fast at each code - mine took three repeated codes.
I have both garages working from the day I brought the car home with no problems. - Two weeks now.
Old Sep 7, 2003 | 07:39 PM
chaz's Avatar
chaz
It actually worked for about 3 months. Then on friday it stopped.
I'm bringing it in to the dealership tomorow... hopefully they will give me one with a compass in it to replace my non-functional one.
Old Sep 8, 2003 | 01:36 AM
Beaker02's Avatar
Beaker02
Mine works fine with the g-door, but i've never been able to take the code for the home alarm. I have to carry a remote in the car.
Old Sep 8, 2003 | 08:24 AM
mark350's Avatar
mark350
I have not had any problems with mine as of yet.....we have had temperatures in the 120's at times also.
Old Sep 10, 2003 | 05:16 AM
Dissolved's Avatar
Dissolved
All you guys having problems have rolling code garage doors right??? So far so good for me (non-rolling code) but I'll keep you updated
Old Sep 10, 2003 | 08:06 AM
danotto's Avatar
danotto
Mine works fine. No problems...
Old Oct 2, 2003 | 06:16 PM
mooch's Avatar
mooch
Mine was working fine for a few weeks then quit. Now I'm not able to even clear the memory. Took it into the dealer today and when they told me they needed to replace the mirror I asked if I could pay the difference and get the one with the compass. They told me that wasnt possible since the compass mirror is a dealer aftermarket product and whatever they replace during a warranty repair has to be replaced with the same part. I thought that sounded bogus but when I called Nissan I was told the same story. Hope this next homelink mirror last longer than a couple week.
I dont have a rolling code on the opener.
Old Oct 3, 2003 | 11:40 AM
christurismohk's Avatar
christurismohk
Mine fails sometime...........The first button don't lite up when I press it while the second and third lights up. The reason I say sometimes is because when i shut my engine off, and turn it back on, then the homelink works again....
3vilbunny
Jul 18, 2017 05:10 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
derekinthez
South East
Sep 28, 2015 06:35 PM
