Advice for servicing
Old Mar 13, 2009 | 08:03 AM
pony_killer's Avatar
pony_killer
Arada ninda apa
Default Advice for servicing
Just a few things I'll be doing for my 30k service...does this sound about right or does anything need to be changed? I did look at the factory service schedule but thought my list seems a bit improved
*Spark plugs
*Transmission Fluid drain/refill
*Differential Drain/refill
*Oil & Filter Change
*Radiator Coolant Flush
*Clutch fluid drain/refill
*Possibly changing brakes to Stoptech Stage 2 (rotors, pads, lines)
*Not sure if any of the belts need to be replaced or not...car is a 2006 with 26k miles on her. Not sure if anything else needs replacement
Will be getting all work done at Overdrive Auto / J-tran
Old Mar 13, 2009 | 09:15 AM
nkohler's Avatar
nkohler
save yourself a good amount of money on labor and parts. the spark plugs should not need changing at 30k miles unless you have played around with your air/fuel a lot and fried them. Maintenance schedule doesn't even call to replace the plugs until 60 or 90k I think.
Old Mar 13, 2009 | 09:33 AM
pony_killer
Arada ninda apa
thanks...will take that off of my list
Old Mar 13, 2009 | 12:19 PM
Bevo's Avatar
Bevo
According to Nissan maintenance schedule, it says replace spark plugs at 105k miles.
Old Mar 14, 2009 | 08:52 PM
I would stick with the recommend maintenance. Items on your list are overkill.
Old Mar 15, 2009 | 04:41 AM
pony_killer
Arada ninda apa
thanks davidv..i might stick with it as well, but i do think its time to change the tranny/diff fluid. shifting is a little knotchy
liqalu04
Jan 2, 2022 12:58 PM
user 62082028
Southern California
Jul 28, 2017 11:47 AM
BumbleZee
OZOC (Orlando Z Owners Club)
Sep 26, 2015 01:00 AM
