Terrible Screetching Noise from the Engine.. Embarrasing!
Old Apr 21, 2009 | 05:30 PM
cipher's Avatar
cipher
Default Terrible Screetching Noise from the Engine.. Embarrasing!
Looked up a few posts about this but want to make this official.... Happens sometimes, like 3 times a week now. whenever i start my car it starts screetching so loud that the car sounds like a piece of SH*T!
Are my Belts Loose? A few posts said this but how do i tell if they are loose? I just had the serpentine (spelling?) belt replaced but not the other one.
I dont know how to fix this noise, what is it, i dont even know if it is the belts, but the noise sounds like an old car that is crying for help! it just gets soo loud thats its unbearable and then it just disappears after 30 secs!
If anyone can help me out that would be great, i dont want to take it to the stealership and tell them all this and watch that it starts up fine.
2003 touring with 80,000 miles on her!
Old Apr 21, 2009 | 05:31 PM
Motormouth's Avatar
Motormouth
dude, that is the ****ing chupacabra.
run.
for your life. burn it. burn it with fire.
Old Apr 21, 2009 | 05:33 PM
cipher's Avatar
cipher
lol... ok that made me laugh a bit...
Old Apr 21, 2009 | 05:43 PM
Motormouth's Avatar
Motormouth
don't be embarrassed by the noise. the chupacabra does what it wants, where it wants.
Old Apr 21, 2009 | 06:28 PM
cipher's Avatar
cipher
it sounds like this but a bit louder and then dissapears in about 10 -15 secs.
http://www.youtube.com/watch?v=_eZfDXwVB2I
Old Apr 21, 2009 | 06:31 PM
cheshirecat79's Avatar
cheshirecat79
I'm going to venture to say it's a Squealing Serpentine Belt.
Change it.
Old Apr 21, 2009 | 06:52 PM
TreeFiddyZee's Avatar
TreeFiddyZee
Do WHAAAAT!?
Belts can squeak if they're too loose, too tight, worn or even if it's cold and damp. With 80k, I'd have to agree that the serpentine is probably toast. Any decent mechanic can look at the belt and tell that it's worn. It doesn't matter if it squeaks or not.
Old Apr 21, 2009 | 06:55 PM
Nexx's Avatar
Nexx
u sure it isnt one of these little bastards?
Old Apr 21, 2009 | 06:59 PM
TreeFiddyZee
Do WHAAAAT!?
run.
Aren't those the suckers that the Spanish classes always sold in school?
Oh no, that's Chupa Chups.
Old Apr 21, 2009 | 07:49 PM
cipher's Avatar
cipher
yeah im thinking that when the mechanic replaced my serpentine belt he just didnt tighten it to spec, how can my belt be bad already, i just had it replaced 2 months ago
Old Apr 22, 2009 | 03:04 AM
TreeFiddyZee
Do WHAAAAT!?
Doh! Guess I need to read a little better. Sounds like you're right on the money. He didn't tighten properly.
Old Apr 22, 2009 | 06:01 AM
jray8's Avatar
jray8
for a quick fix, take a bar of soap and hold against the underside of the belt while the engine is running for a few seconds, takes away the noise, but it's just a temporary fix.
Old Apr 22, 2009 | 06:14 AM
HOMiEZ's Avatar
HOMiEZ
if you only replaced the serpent belt than it sounds like the AC belt is going
Old Apr 22, 2009 | 07:44 AM
cipher's Avatar
cipher
looks like im going to have to get an AC Belt too..
Old Apr 22, 2009 | 08:12 AM
mclovin.too's Avatar
mclovin.too
Check belts (tension as well) then replace if needed.
End.
Old May 3, 2009 | 08:01 AM
GIANNI's Avatar
GIANNI
the tension to lose tighten up all the way TILL YOU GET THAT chupacabra OUT OF THERE
Old May 5, 2009 | 08:52 AM
zippy75's Avatar
zippy75
you using stock pulleys or lightweight pulleys..?? if lightweight pulleys than that's normal.. but only in the morning when u first start ur car.. or when raining.. the sound will go off after 5-10sec after u start ur car..
just my 2cents..
Old May 5, 2009 | 10:57 AM
350 Rookie's Avatar
350 Rookie
To check the belt tension, just simply take the belt and twist it. it should only turn about 90 degrees. If you can flip the belt upside down, then its too loose.
Old May 5, 2009 | 12:45 PM
thekinn's Avatar
thekinn
Interesting. I've been wondering about that since I replaced my belts and wasn't very familiar with belt tension guages (ie.. which one to get and how to read it).
Old May 5, 2009 | 01:27 PM
Jimmyg41's Avatar
Jimmyg41
Sometimes as the starter starts to die off there could be a horrible screech too. It happened with several s14's that I owned.
