Please Help~ I need gas and pushed the button into the dash
Old May 6, 2009 | 06:31 PM
Shannaleanne13's Avatar
Shannaleanne13
Talking Please Help~ I need gas and pushed the button into the dash
I just bought a 2004 350Z and I have only put gas in it twice, and the last time was when the incident happened...I have searched website after website and I can't find an answer on how to fix this issue. Can someone please help me???? I will send presents!!!
Old May 6, 2009 | 06:34 PM
Chromex319's Avatar
Chromex319
Dealership. Too much of a hassle to do it on your own unless you're an expert.
Old May 6, 2009 | 06:38 PM
Mike Wazowski's Avatar
Mike Wazowski
stop taking the steroids...
did you try using a very small screw driver to "pop" it out?
Old May 6, 2009 | 06:52 PM
maXmood's Avatar
maXmood
Under Boost!
do that^... or get a plastic card (credit card look alike), and cut it into 2 pieces. then slip one in each side and then squeeze and pull.. it should come out.
and if that didn't work, then try hitting the side of it with ur fist.. like couple of punches and it should pop out.
Old May 6, 2009 | 07:00 PM
Shannaleanne13
OMG...I never thought of putting down the roids...~ Thank you so much for your help...I have a card that I have been using to get the cup holder out - it could double as a gas tank opener....If I didn't look so good in the car, I would be angry!!!
03aeroZ's Avatar
03aeroZ
Do you mean you pushed the button through the dash...like it is hanging out behind the dash now? If so...just put the button back through the dash, and next time don't push so hard. I did the same thing when I first bought my car and just popped it right back in. Easy fix and NOT worth going to the stealership.
Old May 6, 2009 | 07:04 PM
Shannaleanne13
Actually I pushed it in and now I can't find it....It is like a horrible game of hide and seek and I think I am losing....
Old May 6, 2009 | 07:07 PM
03aeroZ's Avatar
03aeroZ
Lay down so you can look behind the dash from the floor. You should be able to see it hanging down. Take it, put it back in the hole, and push it back in place.
Old May 6, 2009 | 07:12 PM
Shannaleanne13
Really???? That would be fabulous!!! OMG! You guys are the best....I will let you know how that goes...I failed Auto Mechanics in HS - but I just took it to flirt with the boys...Could be why I got this car, as well ~
Old May 6, 2009 | 07:33 PM
SageZ's Avatar
SageZ
can I be your booty call? I live in Beaumont but travel to htown often.. and i drive a z how perfect is that
Old May 6, 2009 | 07:35 PM
SageZ's Avatar
SageZ
second thought, id need to see a pic first
Old May 6, 2009 | 07:38 PM
03aeroZ's Avatar
03aeroZ
^that didn't take long
Old May 6, 2009 | 07:40 PM
SageZ's Avatar
SageZ
I tried to resist but figured it was worth a shot
Old May 6, 2009 | 07:44 PM
03aeroZ's Avatar
03aeroZ
I hope, for your sake, she isn't acura girl
Old May 6, 2009 | 08:32 PM
Chromex319's Avatar
Chromex319
I was thinking that the release mechanism broke.
Old May 7, 2009 | 01:37 AM
maXmood's Avatar
maXmood
Under Boost!
that's what i thought exactly...
Old May 7, 2009 | 12:49 PM
Shannaleanne13
Old May 7, 2009 | 12:53 PM
Shannaleanne13
Damn I don't know how to post a picture.....
Old May 7, 2009 | 03:11 PM
CancerJCCz's Avatar
CancerJCCz
Mine has been pushed in since I bought it. I just reach behind it and stabilize to push it when I fill up! Doesn't bother me.
Old May 7, 2009 | 05:16 PM
Shannaleanne13
ok..I am just going to have to search for it....I guess I just don't know my own strength!!
