Starting problem after spacer install
Old May 10, 2009 | 06:04 PM
can'tZme's Avatar
can'tZme
Question Starting problem after spacer install
I have had this problem ever since I installed my 3/8" powerlab plenum spacer about 3 months ago. From a cold start it starts just fine. Its after its been ran for a little while, shut off, and then started again. It will crank and start fine, but when the RPM's go up right after it starts it drops back down to around 50RPM and almost dies. The whole car shakes and finally after about 1-2 seconds the RPM's raise back to normal idle. It's almost like its not getting enough fuel after the start-up. The car runs fine while driving and idling. Did I mess something up with the spacer install? Please help because I would like to sell my Z this summer and its not a good selling point.
(Don't worry I will be getting another 350Z!)
Old May 10, 2009 | 06:24 PM
DavesZ#3's Avatar
DavesZ#3
Sounds like an air leak or you didn't re-connect the vacuum lines that connect to the upper plenum.
Old May 11, 2009 | 04:40 PM
can'tZme's Avatar
can'tZme
But if it's a air leak wouldn't I notice a problem during load? Also, it doesn't have a problem when I first start it in the morning (cold start) only when it's up to temperture.
Old May 11, 2009 | 05:14 PM
DavesZ#3's Avatar
DavesZ#3
A relatively small air leak will only affect idle or low RPM operation. There are certain enrichments in effect when the engine is cold. Once it warms up and is operating normally, any leaks would be more prevalent.
Check any connectors around the plenum as well. For example, on the back passenger side is where the purge solenoid switch is located. If you accidently disconnected the hose or wiring from it that could cause a problem. I believe there is also a hose from the air intake tube back into the head/PCV valve.
lolwatbro
Oct 9, 2021 04:58 AM
Workshop12
Mar 23, 2020 01:45 PM
pslamp32
Feb 8, 2017 09:07 AM
Juztin
Nov 22, 2015 07:03 AM
