Clutch Problems, Help!
i was pulling my car into the driveway and when i pushed the clutch in it just stays fully depressed, there are only two positions: fully depressed and all the way out; there is no in-between, it seems like there is no pressure
Please do a search.
If you have an '07, there's a recall.
If you don't, you need to:
- Flush out clutch fluid with DOT4 synethic fluid
- Replace the clutch line with a stainless steel line
- Get your master/slave cylinder replaced
- Combination of any of the above.
i did do a search and came up with one result and there were many different ideas to what the problem might be for that person too. i believe it is my slave cylinder and which case i will upgrade my clutch, i was thinking of either the nismo or jwt clutch and flywheel. Which do yall recommed? thanks
