Please help with this cooling system problem
My 350Z has only 41,000 miles and I just noticed yesterday some white milky specs / spots floating on the surface of the coolant expansion tank. I also opened up the radiator cap, to find the same deposits. I then scooped out a little bit of the white stuff, and wiped it on a rag, only to see it was really light brown in color. The expansion tank also has a brown film inside of it on its walls.
I know that this sounds like a bad head gasket, but I refuse to believe it is true. The car's only five years old, 41k miles, and I sure as heck don't beat on it.
I suspect the culprit to be the Redline Water Wetter I added after my last coolant change about 10k miles ago (using Nissan OE coolant). I read someone having a similar problem with brown gunk forming in his cooling system online, so even though I take many things I hear online with a grain of salt, for my sanity I am running with the possibility that the Water Wetter is what is causing this.
I plan to go back to the dealer to flush out the current coolant and replace it with new. I doubt that this will remove the white/brown deposits in the system. What can I, or rather the dealer, do to completely clean the inside of the cooling system? Please help.
