Clutch problems!
Old Jun 17, 2009 | 10:39 AM
LehighGuy's Avatar
LehighGuy
Default Clutch problems!
Since my new clutch install was done (500 miles ago), I have had an incredible amount of clutch chatter starting in first and shifting to second. The chatter only appears after I have been driving the car for at least 20 minutes, otherwise no such issues. Also another strange issue that I fear is related occurs when I pull hard on the highway - the clutch engagement point moves significantly lower, closer to the floor! First time I felt this it really jerked the car. I have since tested it and indeed the engagement point moves with whether or not I am pulling hard or just cruising (I really do not think this is normal).
Any advice?? It is under warranty so I can easily take it in for repairs. The synchros and bearings were also replaced with the clutch.
BTW my Z is an '03 MT performance. Thanks.
Old Jun 23, 2009 | 11:25 AM
LehighGuy's Avatar
LehighGuy
Well I guess nobody had any idea what it was... so I took the liberty to ask my motor-savvy friend who quickly identified the problem. He used a lot of jargon explaining a clutch to me, but what he eventually said is that the clutch was not installed properly, or secured tightly enough and it vibrates with engagement/disengagement. I set up an appointment to take it back in so they can fix what they messed up.
Old Jun 23, 2009 | 11:47 AM
bigcloud's Avatar
bigcloud
Glad you found out what the problem was. Sometimes people don't respond for some reason I don't understand.
Old Jun 26, 2009 | 12:02 PM
Eddie@Performance's Avatar
Eddie@Performance
Performance Nissan
Sometimes the chatter is actually from the carbon fiber driveshaft vibrating (seems to be only at lower rpms), on some of the Z's with aftermarket clutch/flywheel, perhaps thats maybe what you are hearing. The 350Z does have a good amount of drivetrain noise thats normally absorbed by the dual mass flywheel but seems to get louder with age or aftermarket drivetrain parts.
Old Jun 26, 2009 | 12:06 PM
Eddie@Performance
Performance Nissan
On second thought you know what it could be? Maybe they installed the clutch disc on backwards? I heard of someone on G35 driver did that and it started to do something like what you're describing.
Uriyo_
Sep 8, 2021 08:46 AM
TDPrank
Sep 28, 2015 06:29 AM
