got stranded on the side of the road (Diagnosing)
Old Jul 6, 2009 | 09:41 PM
marques1's Avatar
marques1
Default got stranded on the side of the road (Diagnosing)
Ok, well today im doing a little spirited driving. A little heavy acceleration in first gear and all of a sudden my power steering goes out in my car and the battery light and the brake light comes on. My Brakes are fine and so is my battery.
We'll i couldn't bring it in to the shop immediately so i decided i would bring it to the shop the next day to see what the issue is. Well, my car decided that it wanted to die and under acceleration the car has absolutely no power. The pedal is all the way depressed to the floor and the car does not move more than about 5mph.
Then the car dies and once i try to restart it ....it will not crank over. Has anyone encountered this problem and any ideas of what may have caused this. I'm personally thinking an electrical problem.
Old Jul 6, 2009 | 10:51 PM
SageZ's Avatar
SageZ
Check your belts.. if it's standard, will it push start?
Old Jul 7, 2009 | 09:05 AM
350z 6spd's Avatar
350z 6spd
+1 on the belts. If the alternator is not spinning then the car will use the battery until the battery dies and eventually it will not run or crank over. It probably won't start/run long if it is push started because there is not enough power to create a significant spark. The power steering would go out b/c that pump is on the same belt as the alternator.
Old Jul 7, 2009 | 02:24 PM
marques1's Avatar
marques1
oh ok i see!! Thank you for the diagnosing i will tell you guys how it goes...thank you again.
Old Jul 8, 2009 | 02:11 PM
marques1's Avatar
marques1
You guys were right both of my belts broke at the same time, crazy!! Thanks
Old Jul 8, 2009 | 03:18 PM
DavesZ#3's Avatar
DavesZ#3
Both belts broke!!!! The odds against that seem pretty high.
Old Jul 8, 2009 | 03:23 PM
marques1's Avatar
marques1
Yes, that is what i thought also but both broke at the same time.
Old Jul 8, 2009 | 03:37 PM
0jiggy0's Avatar
0jiggy0
Inner one broke and took the other one out. At speed its not uncommon. This is about the cheapest thing that could've happened.
sherm
Apr 11, 2020 05:21 PM
nanotech
Oct 2, 2015 05:02 AM
EnjukuRacing
Sep 30, 2015 06:55 AM
