3hree5neoero - window motor
I had a really hard time putting it back together as it just wouldn't go back in. You just have to keep messing with it and at one point, it'll just all fit together perfectly.
I've been working on getting the shaft back into the window motor for the 3 hours, to no avail. How did you do it?
I have just done with the window motor on the passenger side with my Gf, she helped me alot.
If you are having a hard time doing it by yourself, I am suggesting you get friend to help you on this one, have your friend to hold the panel while you are holding the motor at the back of the panel, align the holes, and have your friend put the screws back in.
the gear with the brushes?
you have to use a small screwdriver to hold back both sides of the brushes while you slide it over the commutator. It's tricky but very doable. 2 small flathead screwdrivers.
