Car sat for 5 straight days now problems
Old Jul 24, 2009 | 01:42 PM
binder's Avatar
binder
so you're only having problems with bank 1. i'm not exactly sure which o2 sensor that would be, the front or rear o2 on that side.
did you ever have codes from the test pipes before? i had to do a non-fouler on mine to stop giving me codes.
Old Jul 24, 2009 | 03:07 PM
Toby-22's Avatar
Toby-22
i think its the passenger side o2 sensor on the headers, not 100% sure. But i never had problems with my testpipes causing codes, i have an 03 so im good on that.
Old Jul 24, 2009 | 03:52 PM
Toby-22's Avatar
Toby-22
bump
Old Jul 24, 2009 | 07:58 PM
binder's Avatar
binder
i would say try that o2 sensor. see how much replacements are. If they aren't expensive i would just replace both front o2 sensors.
i honestly would wait to see if it's condensation in the fuel from sitting with rain. It would suck to get new o2 sensors and just have water in your gas tank.
Old Jul 24, 2009 | 08:13 PM
Toby-22's Avatar
Toby-22
appreciate all the help binder, ima give it couple days and ill check out the o2 sensor/wire and see if its just dirty. If cleaning it dont do anything ill just buy another one.
Old Jul 24, 2009 | 08:44 PM
binder's Avatar
binder
ya. trying HEET in the gas tank would help too if it's a water problem. It's like 1$ so you're not out much.
if you do replace the sensors i would replace the front o2 on both right and left bank because once one of them goes out the other is close behind.
Old Jul 27, 2009 | 11:29 AM
Toby-22's Avatar
Toby-22
Well i decided to just replace my o2 sensor. Unfortunately i dont have the $ to buy new ones, but i can get one used. So for sensor1 bank1 is that the o2 sensor on the passenger side header? Anyway do these look right for the bank1 sensor1 o2 sensor? How can i tell which one is the right one?
OR
Old Jul 27, 2009 | 02:15 PM
Toby-22's Avatar
Toby-22
BUMP^
anyone? Im planning on ordering tonight, just gotta make sure im buying the right one
THanks!!!
Old Jul 27, 2009 | 02:58 PM
Toby-22's Avatar
Toby-22
figured id just buy these
http://www2.partstrain.com/store/det...L/BS15730.html
Old Jul 27, 2009 | 04:16 PM
J-BoneZ's Avatar
J-BoneZ
JPE22,
Is it throwing codes on all of your 02 sensors, because i just recently put test pipes on mine took it to the car wash and they completely ripped the portion where the sensor connects to the pipe, I take it to autozone to get it checked and they said it was all four so I was wondering if one bad one will set all 4 off?
Old Jul 27, 2009 | 04:48 PM
Toby-22's Avatar
Toby-22
the code reader said i had 6 codes but it was all the same. Just to that one sensor sensor1 bank1
Old Jul 31, 2009 | 03:29 PM
Toby-22's Avatar
Toby-22
Well i just got the universal bosch o2 sensor and went to work earlier today with a help of a friend. Anyway i pulled the codes out again and it got 3 different codes-all pretty much the same as the first code cept with two others. The guy at autozone is an IDIOT for telling me its only 1 code. But i went ahead and replaced the bank1 sensor1 o2 sensor.
Good news is the engine light and codes are gone. Bad news is my car still runs funny. Not nearly as bad as before but i still get this hiccup in between revs. Throttle response still feels kinda laggy. Iono maybe its the ECU relearning its self again??? Ill keep everyone updated
Old Jul 31, 2009 | 09:01 PM
binder's Avatar
binder
did you reset the ecu afterwards? unplug the battery for a while and reset the ecu. then it will relearn and things should get back to normal.
you also might still have some bad gas (condensation) going through the tank. that happens in humid areas from time to time.
Old Aug 3, 2009 | 08:25 AM
Toby-22's Avatar
Toby-22
Just cleaned my maf/throttle body and OMG!!!!!! lol car feels so much better. It literally feels like my car lost 300lbs lol. Before when it felt like the car was choking, now it just pulls! When i cleaned the throttle body my micro fiber was black,..thing was really dirty. Anyway if your car has over 60k miles i suggest you clean your maf/throttle body.
Old Aug 3, 2009 | 09:50 AM
binder's Avatar
binder
so the car is back to normal?
Old Aug 3, 2009 | 10:21 AM
Toby-22's Avatar
Toby-22
i think so, it feels good lol. Not as good as my friends Z tho, but then again my Z never felt as smooth/fast as his.
Old Aug 11, 2009 | 01:52 PM
ZAW117's Avatar
ZAW117
Good thread!! Mine has been doing the same thing for two months - ever since I let it sit in a FL. airport lot for a week. I spent way too much time dealing with dealer dorks and replacing "likely" parts. My mods are similar to yours so I'm going to clean the entire intake sys and see what happens...
Thanks to all who gave advise here!!!
Here goes nothing...
Old Aug 11, 2009 | 01:59 PM
  #38
Toby-22's Avatar
Toby-22
haha glad it helped, however cleaning out the intake system didnt solve the problem. Getting rid of my code (which was replacing the o2 sensor) did. THe only thing cleaning out the maf/throttle body did was make my car feel a lot faster/smoother. If your car isnt throwing any codes then go ahead and clean them, maybe it will make it run like new again.
PS i have bigger problems with my Z now lol
Old Aug 11, 2009 | 08:08 PM
  #39
binder's Avatar
binder
what problems?
Old Aug 11, 2009 | 08:15 PM
  #40
Toby-22's Avatar
Toby-22
https://my350z.com/forum/maintenance...o300-code.html
That! But after researching i think its just a vacuum leak. Ima check tomorrow. I took off the plenum for painting.
Me and this guy have the same problem and both took off plenum/plenum spacer, if its not a leak ima just bring it to nissan
pslamp32
Feb 8, 2017 09:07 AM
OdesiTT
Sep 30, 2015 10:47 AM
350z_z33.
Sep 9, 2015 09:50 PM
