Alignment Help
Old Oct 5, 2003 | 04:55 AM
hugo1669's Avatar
hugo1669
Default Alignment Help
I took my Z to get the Tire feathering Issue verified and here are the before and after numbers. The service manager told me that "It wasn't Bad" . To me it looks "Bad" .They performed the tire swap and sent me on my way. I requested new tires but they told me that they had to follow procedure.
Can someone that knows about alignment numbers let me know if mine were "Bad".
Heres the before:
Old Oct 5, 2003 | 04:56 AM
hugo1669's Avatar
hugo1669
And after,. Also are they using Nissans current specs? They're different then what I found on here.
Old Oct 5, 2003 | 03:11 PM
zwindsor's Avatar
zwindsor
Twisty addict
The "new" numbers are well within specs and are quite good. Your original "toe" numbers were pretty high but are fine now. You can't adjust anything else in the front.
Old Oct 5, 2003 | 03:15 PM
zwindsor's Avatar
zwindsor
Twisty addict
PS. the specs they are using are current
Old Oct 6, 2003 | 04:12 AM
hugo1669's Avatar
hugo1669
Thanks zwindsor. I'm just tring to gather some info for my case number.
emooheo
Oct 14, 2015 08:58 AM
Depravity
Oct 1, 2015 04:49 PM
EnjukuRacing
Drivetrain
Sep 14, 2015 11:15 AM
