Fuel tank won't accept more!
Old Sep 19, 2009 | 08:29 PM
fatlace_ak21's Avatar
fatlace_ak21
Originally Posted by stormcrow
*insert facepalm here*
buy the parts for the recall. have it installed by any dealer or do it yourself... it's fairly straight forward and if IIRC, it's only three parts.
the "turn the pump upside down" was meant to be a joke. as A) you can't turn the pump upside down...the nozzle, yes, but not the pump... and B) the problem is created by vapor not being able to leave the tank which causes it to either overflow or disable the nozzle due to the back pressure...
haha, I didnt realize that was a joke but now that i think about it there's no way that'll work. I do all the work on the car myself so I'll just have to fix it one day. What actually needs to be changed out, location?
Old Sep 20, 2009 | 06:44 AM
stormcrow's Avatar
stormcrow
it's been a long while since i performed my install... but, if i remember correctly, it's two hoses and a few clamps. the gas tank has to be dropped, though. your dealer will know exactly which parts and if you ask, they will even print out the TSB on how to perform the work.
Old Dec 27, 2013 | 09:00 PM
Gonzo_92's Avatar
Gonzo_92
wow. is this thread still going?
ok. being kind here. to all of you n00bs who fail at searching or checking with the dealer - there's a fuel filler neck recall for the 350Z that's been out for, oh, 4 years now. go to you local nissan dealer and have it performed.
Just a quick question, so even though I don't have any warranty on my car I can still get the problem fixed if it's a recall?
Old Dec 28, 2013 | 05:44 AM
92K1500's Avatar
92K1500
It's a TSB, not a recall. They will charge you to do it.
I thought I had this problem because it showed I was out of fuel at 200 miles. Turns out my sending units are bad. Been driving on it for 5 years now and have put 433 miles on a tank. Took 19.25 gallons to fill up, so I know it's getting all the way full.
May 30, 2017 03:28 PM
