Maintence for the Z with 35,000 miles
Old Sep 15, 2009 | 06:46 PM
Blackheart's Avatar
Blackheart
Default Maintence for the Z with 35,000 miles
Hello Everyone,
I have had the 06 Z for three years now and has been maintained with oil changes every 2500 miles and just got new tires for my aftermarket wheels. The Z the Z just approached 35000 miles and it is my daily driver. I would take her to the dealer but I know they would charge an arm and a leg and then some. Is the anything else that I would need to do to her to make sure she continues to run fine.
Any Suggestions?
Thank for your time everyone.
Sincerely -BH
Old Sep 16, 2009 | 10:11 AM
WhiteNoiz's Avatar
WhiteNoiz
Tranny fluid change
Rear diff fluid change
Coolant change
Belts (you could probably wait on this, I did mine at 48k)
Old Sep 16, 2009 | 12:03 PM
lgear080's Avatar
lgear080
alignment? think he hit all the high notes above^
Old Sep 16, 2009 | 02:15 PM
vthao's Avatar
vthao
Fuel filter, air filter.
Old Sep 17, 2009 | 09:07 AM
Blackheart's Avatar
Blackheart
ok fluids I understand. I have been checking those and they are not low or anything. BUt a change of fluids would be bad. Better do that as well.
Anything else guys? and thanks for all the info.
Old Sep 17, 2009 | 02:29 PM
thekinn's Avatar
thekinn
I think the fuel filter is inside the tank/part of the pump. You may want to skip that.. I'm not finding anything that suggests that is necessary (at least on the 2006).
Definately check/replace that air filter though if you haven't already.
PCV valve?
Old Sep 21, 2009 | 08:53 PM
Blackheart's Avatar
Blackheart
well I got the Pcv valve. 12.00 bucks so I may as well change it. I just got the fluids done need another 1000 before changing the oil.
I still have to change the:
Air filter
tranny fluid
coolant fluid
fuel filter- only needs to be changed if fuel pump goes out according to 4 techs.
Question is I still have to do the REAR DIFFERENTIAL Fluid. but what specific type is it?
I went to ask at NAPA and AUTOZONE stores and they have several types but they have no idea which one it is.
Any REcommendations?
I hope this thread helps other members as well. Thanks guys!
Old Sep 21, 2009 | 10:35 PM
tw8715's Avatar
tw8715
this is what i use.
http://www.amsoil.com/storefront/svg.aspx
Old Sep 22, 2009 | 05:59 AM
Blackheart's Avatar
Blackheart
AMSOIL 75W-90 ok cool thanks man!
Old Sep 22, 2009 | 07:09 AM
j.arnaldo's Avatar
j.arnaldo
"Owners' Manual Scheduled Maintenance".
Old Sep 22, 2009 | 12:29 PM
Bevo's Avatar
Bevo
Owner's manual recommands NISSAN Differential Oil Hypoid Super GL-5 80W-90.
Old Sep 22, 2009 | 01:03 PM
WhiteNoiz's Avatar
WhiteNoiz
keep in mind you dont have to use Amsoil if its hard to get in your area
Old Oct 8, 2009 | 06:35 PM
Exodus751's Avatar
Exodus751
air filter oil change check brakes/ tires belts trans fluid diff fluid antifreeze while at it visual check everything you should be good
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
