CEL knock sensor...could this be the problem
Old Oct 19, 2009 | 04:41 PM
GriffinZ33's Avatar
GriffinZ33
Question CEL knock sensor...could this be the problem
well a couple days ago my cel came on and i took it to autozone they told me its the knock sensor. so i got the new sensor and harness now im starting to take it apart and i noticed this... there is some wire still connected could this be why the knock sensor went off?
Attached Thumbnails CEL knock sensor...could this be the problem-100_0217.jpg
Old Oct 19, 2009 | 05:16 PM
GriffinZ33's Avatar
GriffinZ33
found another problem the knock sensor harness is melted off any idea why that happened
Old Nov 1, 2009 | 05:51 PM
bottlefedZ's Avatar
bottlefedZ
Did it fix your problem?Where did you purchase the harness?
Old Nov 2, 2009 | 06:02 PM
pchio's Avatar
pchio
Yes, the broken wire generate more resistance and throw off your computer reading. Maybe the harness clips are loose/broken so the wires are touching the hot surface?
Buying a whole harness is expensive, you can try to get the same gauge wires, cut the burn off one and solder the new wires.
Old Nov 20, 2009 | 02:29 AM
pagaal4u's Avatar
pagaal4u
I had a freaking mouse chew up my knock sensor wire harness. I was able to get a part # after harrassing the dealer and Nissan. The part # for the knock sensor sub harness is 24079-CD000. Hope this helps..
I need help replacing my wire harness and live in the San Francisco Bay Area if anyone is willing.
Old Nov 20, 2009 | 03:13 AM
bottlefedZ's Avatar
bottlefedZ
Great info,Thanks
Old Nov 20, 2009 | 10:26 AM
pagaal4u's Avatar
pagaal4u
the part is available through Courtesy Nissan as well for $70. You can save a little money since they take soo much of it from us already.
Old Mar 25, 2012 | 07:33 AM
Maddawg's Avatar
Maddawg
had the same result. r&r'd sensor and harness and gained over 55 whp. thanks to Z Car Garage in San Jose...
Old Mar 25, 2012 | 01:35 PM
JaE35z's Avatar
JaE35z
z1 now also sells the harness by itself for 20-30 bucks
Uriyo_
Sep 8, 2021 08:46 AM
TDPrank
Sep 28, 2015 06:29 AM
