P1163 pending code
Old Oct 28, 2009 | 06:58 PM
ms350z's Avatar
ms350z
Default P1163 pending code
I have an 03 350z w/ 67k miles and the SES light IS NOT on, however I hooked up my diagnostic scanner just for fun and I found there is a PENDING code for P1163 so I imagine the code may pop up soon. The car runs fine other than a very slight stumble at idle here and there. From my research I have found that this means one of the following:
P1163 Heated O2 Sensor 1
P1163 Heated Oxygen Sensor 1 Lean Shift Monitoring (Bank 2)
I have also read in other Nissan forums that when receiving this code it is a good idea to first check for a dirty MAF and bad grounds, which I plan to do. Does anybody have any other suggestions on what to check before replacing the expensive o2 sensor? Thanks in advance.
Old Nov 4, 2009 | 06:15 AM
ms350z's Avatar
ms350z
Update: SES light came on, but the code found is different from the original... but with the same general meaning. The code found is P0174 Fuel System Lean, Bank 2. Both the previous pending code and the current code point to Bank 2 specifically. I would think if it is the MAF it would not be specific to one bank. I'm thinking o2 sensor on bank 2 or dirty/clogged fuel injector.. has anybody experienced this code, if so what was the solution?
Old Nov 4, 2009 | 06:22 AM
TheMinel's Avatar
TheMinel
any mods on the car?
Old Nov 4, 2009 | 06:53 AM
ms350z's Avatar
ms350z
Car is bone stock mechanically.
Old Nov 4, 2009 | 06:55 AM
TheMinel's Avatar
TheMinel
I asked because I just got the code myself, but I have decats (alongside twin turbos) and despite the non-foulers, I think it's due to that, really.
Old Nov 5, 2009 | 06:46 AM
Exodus751's Avatar
Exodus751
so what r your mods? obviously its not stock if u say that
Old Nov 5, 2009 | 06:50 AM
ms350z's Avatar
ms350z
I say that because the only modifications are cosmetic... aluminum grill on the front of the car and window tint. I'm pretty sure neither of these are causing a lean fuel mixture on bank 2.....
Old Nov 15, 2009 | 04:04 PM
ms350z's Avatar
ms350z
Unfortunately nobody here was able to provide any help, so I will follow-up in hopes that this thread will help somebody in the future. I connected the diagnostic cable and monitored the bank 2 o2 sensor readings on several occasions and saw that bank 2 would stay in warm up mode excessively long then stay in open loop due to system fault on bank 2. Also, the voltage for bank 2 o2 sensor was not fluctuating back and forth like it should, it tended to just stay around .290 volts. I replaced the bank 2 sensor 1 o2 sensor and now the voltage readings are normal and there are no pending codes and no SES light on
Old Nov 15, 2009 | 04:33 PM
DSLisFREE's Avatar
DSLisFREE
While you're at it, remind us which one is the Bank 2 Sensor 1 O2 sensor?
Old Nov 15, 2009 | 04:38 PM
ms350z's Avatar
ms350z
Bank 2 sensor 1 is the driver's side (assuming your car is left hand drive) o2 sensor before the cat.
etkms
Jun 19, 2022 06:30 PM
BEBO'S ZEE
Jun 7, 2016 07:48 AM
350Z Project X
Oct 17, 2015 05:16 PM
Detailed Image
Cleaning & Detailing
Sep 28, 2015 03:03 AM
