clutch fluid problem..
Old Oct 29, 2009 | 03:01 PM
Panu's Avatar
Panu
Default clutch fluid problem..
How many quarts of clutch fluid do we need for clutch flush?...thxs ahead
Old Oct 29, 2009 | 03:08 PM
NISMO_558's Avatar
NISMO_558
you'll need 4
Old Oct 29, 2009 | 04:09 PM
DavesZ#3's Avatar
DavesZ#3
Originally Posted by NISMO_558
you'll need 4
Huh?
You're thinking about the MT gear oil capacity.
OP - Considering the small size of the reservoir, the small size of the master and slave cylinders and how short the line is between, I'm thinking one or two pints max.
Old Oct 29, 2009 | 07:12 PM
MDeezy's Avatar
MDeezy
there is no real definate answer but I'd suggest getting the little you shouldn't need it all and you can keep it for the next time or use it to top of your break fluid.
If you bleed properly then you shouldnt need much but if you accidentally get air into the lines you need to flush even more to make sure you have all the air out...
Old Nov 5, 2009 | 11:10 AM
pchio's Avatar
pchio
1 12 fl.oz bottle is more than enough, if you have done it right
lapham3
Oct 7, 2022 03:15 PM
burglapfd
Dec 6, 2020 01:04 PM
sherm
Apr 11, 2020 05:21 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
