Idle drops when giving gas during warm up???
Old Oct 30, 2009 | 07:29 AM
PrOjEcT ZeE's Avatar
PrOjEcT ZeE
Default Idle drops when giving gas during warm up???
Just like the title says... in the morning when i'm warming up the car, I press on the Acceleration pedal (in neutral) the RPM goes up to about 3 thousand and when it drops, it drops down to or close to 0? can anyone tell me what can be the problem?
MODS on the engine are- 1/2" spacer, JWT pop charger, oil and filter was always change at the dealer until it hit 16 thousand miles after that i've been testing out different oil could that be the problem? some one please help..
Old Oct 30, 2009 | 08:08 AM
Chasecbc's Avatar
Chasecbc
Im pretty sure that's normal, i have a lightweight flywheel and mine dose that all the time. Its just the flywheel decelerating, Do the rpms just drop low or dose the car actually stutter or stall?
Old Oct 30, 2009 | 08:57 AM
PrOjEcT ZeE
yeah it does that(stutter/want to stall).. but i have the OEM flywheel and clutch with 44 thousand miles on it..clutch is still good..
and also there's an noise coming from the bottom or the engine bay of the car when it's around 2 thousand to 3 thousand RPM? is that normal
hey my dyno is some what close to what you have..
Old Oct 30, 2009 | 09:51 AM
The car has a cold and hot idle. I have posted both several times.
Old Oct 30, 2009 | 10:12 AM
Chasecbc's Avatar
Chasecbc
The noise may be the throw out bearing?
Old Oct 30, 2009 | 12:59 PM
DemitriHKS's Avatar
DemitriHKS
Mine does this too, Mods are in my signature. I've hear that spacers will increase that though if they are not done perfectly as well. Did it start doing it when you put the 1/2 inch spacer in?
Old Nov 2, 2009 | 06:14 PM
pchio's Avatar
pchio
ya, more info please? Did it happen after you installed the mod? Did you do a ECU reset, so the car can re-learn your idle?
Old Nov 6, 2009 | 08:33 AM
PrOjEcT ZeE
i did all my mods around 05 it is now late 09.. problem just started.. and when i did the mods right after after i had it dyno and tuned... it only has 45K one the car now.
Old Nov 6, 2009 | 08:36 AM
PrOjEcT ZeE
what noise??? we're talking about the idle ...
