Ambient temperature Sensor
Old Nov 4, 2009 | 10:55 PM
wannabuy350z's Avatar
wannabuy350z
Default Ambient temperature Sensor
Greetings everyone,
My Z has travel half way across the world, and originally purchased in the U.S. so the readings are in Fahrenheit. average outside temps nowadays here are 33-29 Celsius so for 33c = 91f but I get 115 120 sometimes.
the vehicle has all the performance mods you can think of. but in the US i never had a problem and reading were always fine. i didnt change a thing since its journey to the middle east.
any idea's?
where is the sensor anyway? I believe its infront of the radiator but all i see is the steering cooler. and my A/C works perfectly fine.
Old Nov 5, 2009 | 03:18 AM
DavesZ#3's Avatar
DavesZ#3
The sensor is located at the front of the car, just below the hood latch.
Temeratures normally read higher than the true ambient temperature because your car is out in the sun, on hot pavement. Mine typically reads about +5 higher when moving. If you're stopped in traffic, heat from the engine and radiator will cause the reading to be even higher.
Old Nov 5, 2009 | 06:18 PM
wannabuy350z
but my car reads about 30 degree's higher. and increase when driving??? which doesnt make since. ambient temp are displayed in the city and my reading is really off. would cleaning it make a difference?
thanks!
Old Nov 5, 2009 | 06:25 PM
DavesZ#3's Avatar
DavesZ#3
That might help but it could be that the sensor has just gone bad. 30º is pretty far off.
Old Nov 5, 2009 | 06:28 PM
Nexx's Avatar
Nexx
personally i think its useless anyways. its always off.
Old Nov 7, 2009 | 05:56 AM
wannabuy350z
I think i know whats the reason. the location of the sensor is 20 inches below the latch. and its rubbing on my intercooler. which is why i think it reads even higher when i get into boost. need to relocate it!
Old Mar 21, 2012 | 12:06 PM
mnkyd21's Avatar
mnkyd21
Hi all. Its about 75 degrees and hot in Cali today, but my temperature sensor is reading 47 degrees, and then moved up later in teh afternoon to 50... so its working but its wrong. Any advice on what to do. I believe i located it under the hood.. so should i clean it off? or reset it by disconneting the battery for a bit?
Thanks for the advice!
Old Jul 1, 2012 | 03:33 PM
e30cabrio's Avatar
e30cabrio
My ambient is stuck at 79. (it is 116 right now) I pulled the sensor......79! Do they just drop dead out of the blue?
Is there any reset that can be done?
Old Jul 1, 2012 | 03:36 PM
TehkMob's Avatar
TehkMob
Actually that sensor helps you ecu run your car... If its broken you timing will be off one way or the other...
Its a two wire plug in the center of your radiator.
IF it gets excessively wet it will mess it up.
Old Jul 1, 2012 | 05:20 PM
e30cabrio's Avatar
e30cabrio
Put it in the freezer, still 79. Pulled the battery for 10 minutes 105.
liqalu04
Jan 2, 2022 12:58 PM
2ndchanceZ
Oct 26, 2015 08:03 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
