quick question about cooling fans
Old Nov 5, 2009 | 06:33 AM
ms350z's Avatar
ms350z
Default quick question about cooling fans
Should both cooling fans automatically come on when the AC is turned on in a 2003 350z? In every other car I have owned both fans automatically come on with the AC, however only the passenger side fan is turning on when I turn on the AC in my 350z. Before I start troubleshooting the relay/fan motor/etc. I want to make sure that both fans should be coming on with the AC on. Thanks.
Old Nov 5, 2009 | 11:14 AM
pchio's Avatar
pchio
Yes both fans will turn on
Old Nov 6, 2009 | 09:56 AM
ms350z's Avatar
ms350z
Ok I found that the driver's side fan will spin if the blades are given a nudge, but very weakly, it is not pushing nearly as much air as the other fan and the blades can be stopped easily. Time to replace the fan motor, wooo.
Old Nov 9, 2009 | 12:41 AM
pchio's Avatar
pchio
Before you do that, check with your Nissan dealership for a possibly warranty extension on the radiator fan motor. I just received a letter showing the fan motor extended to 84months/80000 miles.
Old Nov 11, 2009 | 07:18 AM
ms350z's Avatar
ms350z
I saw the thread regarding this, unfortunately it is only for 04-06 models, and I have an 03. I found an exact fit motor online w/ lifetime warranty for $38, so I will see how that goes. Thanks for the info!
lapham3
Oct 7, 2022 03:15 PM
350Z_Al
Oct 29, 2020 07:44 PM
issyz
Jul 2, 2017 03:04 PM
SharX59
Sep 30, 2015 10:54 AM
