Weird window problem
Old Nov 12, 2009 | 02:50 AM
allycat's Avatar
allycat
Default Weird window problem
ok, before you blast me for not searching, I did do a search and I read every thread on here about window problems and I didn't see what my driver's side window is doing.
Here is the problem I have my driver's window works fine, expect if I had the window open any amount at all while driving or parked. I close the window (either using auto up or holding the up button, I tried both) when I shut the door the window will roll halfway or all the way back down. The only time it does it is when I first get out of the car, if I open the door 5 minutes later and shut it the window is fine. Trying to figure this out is this a motor problem or a loose connection somewere, any help you can give would be appreciated.
Also I have already tried doing the window reset procedure and that didn't help.
Old Nov 12, 2009 | 05:06 AM
GT-Z's Avatar
GT-Z
The motor is goin bad or sum repl it and didnt put the rubber peice under the mirror in the door where the window rides up & down on back in right. either or u have to take it apart and see ur self whats wrong with it. its not that hard have someone help u and u can have it done in no time...
Old Nov 16, 2009 | 05:43 AM
allycat's Avatar
allycat
It does look like the motor was replaced when I took the panel off to put in new speakers a couple of the screws weren't tight and the black dot that goes over the reset button for the window was peeled up. But can you tell me what rubber piece you are talking about, do you happen to have a pic of it. I am going to take it apart and look this weekend. The wierd thing is the window will only go down if you slam the door, if you close it easily it's fine.
Uriyo_
Sep 8, 2021 08:46 AM
TDPrank
Sep 28, 2015 06:29 AM
