Replaced Window Motor + still not working _SEARCHED_
Old Nov 19, 2009 | 03:32 PM
skunk281's Avatar
skunk281
Default Replaced Window Motor + still not working _SEARCHED_
I just replaced my drivers side window motor and will be replacing my pass motor if i can get an answer or suggestion.
But after replacing the drivers side i put everything back and it still doesnt work.
I apply the switch and it clicks but no movement i dont even here a hum of the motor like if there was electricity going thru.
Even connected the new pass motor and nothing so i dnt think its the motors.
Oh and i even tried the reset.
Help any is useful!
Thanks!
Old Nov 20, 2009 | 07:50 AM
ms350z's Avatar
ms350z
Did you check page 14 of the sticky about replacing the window motor where somebody mentioned bent pins in the connector?
Old Nov 20, 2009 | 11:13 AM
skunk281's Avatar
skunk281
Yep.
Tried what jay z has described and nothing still.
Installed the new pass motor and everything is fine i can even roll it up from the main switch. The drivers side however still wont budge!
I connected the new drivers side motor nothing pass side motor on the drivers side nothing.
Sooo heres what i think maybe be wrong.
Main drivers side window switch circuit looks burnt.
What do you all think?
Old Nov 20, 2009 | 11:32 AM
ms350z's Avatar
ms350z
I concur, that circuit is burnt, glad you found the problem!
Siqcology
Sep 18, 2019 01:45 PM
Vigman
Nov 17, 2015 04:34 AM
Shane86
Sep 17, 2015 05:33 PM
AP350z223
Sep 8, 2015 04:38 PM
