All TSBs asof October 17th taken straight from NHTSA
Old Oct 17, 2003 | 07:56 AM
350trackz's Avatar
350trackz
Exclamation All TSBs asof October 17th taken straight from NHTSA
Technical Service Bulletins - Search Results
Office of Defects Investigation
Report Date : October 17, 2003 at 11:51 AM
TYPE : VEHICLE
YEAR : 2003
MAKE : NISSAN
MODEL : 350Z
Make : NISSAN Model : 350Z Year : 2003
Service Bulletin Num : 02120A Date of Bulletin: JUL 07, 2003
Component: SERVICE BRAKES, HYDRAULIC:ANTILOCK
Summary:
VEHICLE MAY EXHIBIT ANTILOCK BRAKING SYSTEM (ABS) LIGHT ON AND / OR DIAGNOSTIC
TROUBLE CODE FOR ABS WHEEL SPEED SENSOR. VARIOUS MODELS INCLUDING THE 2004 QUEST AND
MAXIMA. *TT
Service Bulletin Num : 03063 Date of Bulletin: JUN 25, 2003
Component: SEATS
Summary:
FRONT CLOTH SEAT BOLSTER WORN. *TT
Service Bulletin Num : 03042 Date of Bulletin: JUN 24, 2003
Component: EQUIPMENT:ELECTRICAL:NAVIGATIONAL SYSTEM(GLOBAL POSITIONING SYSTEM)
Summary:
NAVIGATION SYSTEM STUCK ON PLEASE WAIT SCREEN. *TT
Service Bulletin Num : 03006A Date of Bulletin: JUN 23, 2003
Component: SUSPENSION
Summary:
TIRE ROAD NOISE WHEN BRAKING. *TT
Service Bulletin Num : 02115B Date of Bulletin: JUN 04, 2003
Page 1 of 5 NHTSA ODI - Technical Service Bulletins
10/17/03 http://www-odi.nhtsa.dot.gov/cars/pr...Type=DrillD...
Component: ELECTRICAL SYSTEM
Summary:
MALFUNCTION INDICATOR LAMP (MIL) ON WITH DIAGNOSTIC TROUBLE CODE (DTC) P-442 (EVAP
VERY SMALL LEAK) STORED IN SELF DIAGNOSIS RESULTS. *TT
Service Bulletin Num : 03046 Date of Bulletin: APR 25, 2003
Summary:
STEERING DRIFT TO THE RIGHT. *TT
Service Bulletin Num : 03029 Date of Bulletin: APR 02, 2003
Component: VISIBILITY:GLASS, SIDE/REAR
Summary:
GREASE MARK OR STREAK ON INSIDE OF DOOR GLASS AFTER THE WINDOW HAS BEEN LOWERED
AND THEN RAISED. *TT
Service Bulletin Num : NTB02101A Date of Bulletin: FEB 05, 2003
Component: ENGINE AND ENGINE COOLING:ENGINE
Summary:
ON SOME VEHICLE'S THE ENGINE WILL NOT START. *JB
Service Bulletin Num : NTB02070A Date of Bulletin: FEB 05, 2003
Component: TIRES:PRESSURE MONITORING AND REGULATING SYSTEMS
Summary:
INFORMATION ON LOW TIRE PRESSURE MONITOR SYSTEM. *JB
Service Bulletin Num : 03006 Date of Bulletin: JAN 23, 2003
Summary:
Service Bulletin Num : 03001 Date of Bulletin: JAN 09, 2003
Component: INTERIOR LIGHTING
Summary:
INTERIOR COURTESY LAMPS INOPERATIVE. *TT
Page 2 of 5 NHTSA ODI - Technical Service Bulletins
Service Bulletin Num : 02120 Date of Bulletin: DEC 05, 2002
Summary:
TROUBLE CODE FOR ABS WHEEL SPEED SENSOR. *TT
Service Bulletin Num : 02115 Date of Bulletin: OCT 25, 2002
Summary:
MALFUNCTION INDICATOR LAMP ON WITH DIAGNOSTIC TROUBLE CODE P0442 (EVAP SMALL LEAK)
Service Bulletin Num : 02102 Date of Bulletin: OCT 09, 2002
Component: POWER TRAIN:MANUAL TRANSMISSION
Summary:
MANUAL TRANSMISSION SHIFT **** NOT STRAIGHT. *TT
Service Bulletin Num : 02101 Date of Bulletin: OCT 03, 2002
Summary:
ENGINE WON'T START, KEY FOB INOPERATIVE AFTER BODY CONTROL MODULE (BCM) REPLACEMENT.
*TT
Service Bulletin Num : 02100 Date of Bulletin: OCT 02, 2002
Summary:
TIRE PRESSURE MONITOR SYSTEM (TPMS) WARNING LIGHT FLASHES OR STAYS ON. *TT
Service Bulletin Num : 02097 Date of Bulletin: OCT 01, 2002
Component: EQUIPMENT:ELECTRICAL:AIR CONDITIONER
Summary:
BUZZ OR GROWL TYPE NOISE FROM ENGINE AREA WITH AIR CONDITIONER ON. *TT
Service Bulletin Num : NTB02097 Date of Bulletin: OCT 01, 2002
Page 3 of 5 NHTSA ODI - Technical Service Bulletins
Component: ENGINE AND ENGINE COOLING:ENGINE:GASOLINE
Summary:
INFORMATION ON DIAGNOSING NOISE FROM THE ENGINE AREA WITH THE AIR CONDITIONER ON.
*TT
Service Bulletin Num : 02098 Date of Bulletin: SEP 26, 2002
Component: VISIBILITY:WINDSHIELD WIPER/WASHER
Summary:
WINDSHIELD WASHER FLUID SEEPAGE. *TT
Service Bulletin Num : NTB02098 Date of Bulletin: SEP 26, 2002
Summary:
INFORMATION ON VEHICLES EXHBITING WINDSHIELD WASHER FLUID SEEPING FROM UNDER THE
RIGHT FRONT AREA ESPECIALLY AFTER REFILLING THE WASHER FLUID RESERVOIR. *TT
Service Bulletin Num : NTB02077 Date of Bulletin: AUG 01, 2002
Component: OTHER
Summary:
SUBJECT REGARDING ESSENTIAL TOOL: TIRE PRESSURE MONITOR SYSTEM INITIALIZATION TOOL.
*JG
Service Bulletin Num : NTB02075 Date of Bulletin: JUL 17, 2002
Component: POWER TRAIN:AUTOMATIC TRANSMISSION
Summary:
SUBJECT REGARDING SPECIAL AUTOMATIC TRANSMISSION FLUID REQUIREMENTS. *JG
Service Bulletin Num : NTB02071 Date of Bulletin: JUL 15, 2002
Summary:
SUBJECT REGARDING ENGINE NOT STARTING OR NVIS/NATS SYSTEM DESCRIPTION AND KEY
REGISTRATION. *JG
Service Bulletin Num : NTB02070 Date of Bulletin: JUL 15, 2002
Component: TIRES
Page 4 of 5 NHTSA ODI - Technical Service Bulletins
Summary:
SUBJECT REGARDING LOW TIRE PRESSURE MONITOR SYSTEM. *JG
Service Bulletin Num : NTB02072 Date of Bulletin: JUL 15, 2002
Component: ELECTRICAL SYSTEM:BATTERY
Summary:
SUBJECT REGARDING BATTERY SERVICE PRECAUTIONS. *JG
Page 5 of 5 NHTSA ODI - Technical Service Bulletins
Old Nov 6, 2003 | 12:49 PM
cashorgolf's Avatar
cashorgolf
Default Thanks
Thanks for the information....I appreciate it. I was just getting ready to drop a couple of bucks and jump on the Nissan TSB website to see what was new.
nanotech
Oct 2, 2015 05:02 AM
Depravity
Oct 1, 2015 04:49 PM
