heater hit and miss
Old Dec 2, 2009 | 04:39 PM
bogie1519's Avatar
bogie1519
Default heater hit and miss
ok its getting cold outside so tried to set heating in my z. used the auto setting,turned **** all the way over to 90. nothing until car is reved up.
at idle won't heat. anyone seen this problem? or what is best setting to warm up cabin. thanks for any help
Old Dec 2, 2009 | 04:48 PM
DavesZ#3's Avatar
DavesZ#3
You either have air in the coolant system or it's low on fluid.
Old Dec 2, 2009 | 06:35 PM
krnzzang84's Avatar
krnzzang84
if you set it auto, blower will not blow untile it is warmed up. try to put everything manual
Old Dec 2, 2009 | 06:49 PM
Z_Nick_Z's Avatar
Z_Nick_Z
check the coolant level. i had the same exact problem and turned out to just be low level
Old Dec 3, 2009 | 04:19 AM
bogie1519's Avatar
bogie1519
thanks for the tips i'll try today. i fill fluid level first.
Old Dec 3, 2009 | 04:52 AM
Jarred@Z1's Avatar
Jarred@Z1
Z1 Motorsports
yeah your fluid probly got too low and now you have a air pocket in your cooling system. theres a ton of threads of how to fix it.
Old Dec 13, 2009 | 09:39 PM
NISMOFO's Avatar
NISMOFO
It sounds like I have a similar issue (I use the manual setting for the heater) when the car is stopped & running the heater blows cold air....but when I am driving it starts blowing warm/hot air again.
Jambo016
Sep 16, 2016 01:08 PM
TrboMike
North East
Sep 28, 2015 06:36 PM
pslamp32
Sep 14, 2015 03:05 PM
