Help belts squeeling
Old Dec 24, 2009 | 02:21 PM
vdemon311's Avatar
vdemon311
Default Help belts squeeling
Just had my belts changed. sometimes they squeel... soemtimes they dont. After speeding up and changing to about 4th... it goes away. Are they just loose? Should i just tighten them a little? experts please
Old Dec 24, 2009 | 02:38 PM
dmroberson's Avatar
dmroberson
Check the tension on the belts. Sounds like they might be a bit loose
Should be about 1/4 inch of deflection, if you were to press down or pull up on the belt, shouldn't move more than about 1/4 inch. Also, if you twist the belt, should not be able to twist to 90 degrees. That's how I did mine, and have no problems. Changed mine this past Monday.
Old Dec 24, 2009 | 04:16 PM
04fairlazdyz's Avatar
04fairlazdyz
LOW N SLO
^^^Agreed, I change belts everyday of the week. I usually just twist it like said above
Old Dec 25, 2009 | 07:30 AM
vdemon311's Avatar
vdemon311
thanks guys just tightened my belts this morning, no squeeling.
Old Dec 29, 2009 | 09:39 PM
SK350z's Avatar
SK350z
how do you tighten the belts?? I previously had my belts squeaking when the cold weather kicked in
SonnyWu
Nov 24, 2015 08:19 PM
Vigman
Nov 17, 2015 04:34 AM
Fixxxercask
Nov 9, 2015 11:10 AM
Calinismo350z
Sep 14, 2015 04:04 PM
