Speedometer periodicly doesn't work but can temp. fix
Old Jan 17, 2010 | 09:34 AM
Nackers's Avatar
Nackers
Default Speedometer periodicly doesn't work but can temp. fix
Here is the issue.
I start the car and drive it around and everything is cool.
At some point during the drive, after completely stopping and going numerous times, I'll come to a stop and when I start to go, the speedometer is stuck at 0 (both analog and digital).
This will go on for some time untill I shut the car off and restart it. Then its fine for a while untill the process starts over. I've shut the car off and restarted it both while sitting still, and driving and it works either way.
After searching I've noticed others have had speedometer problems, but not like this. I was curious if anyone had any idea why it would do this.
Bad speed sensor? Bad gauge cluster? Maybe something to do with the ecu?
Thanks for any help.
Old Jan 17, 2010 | 09:40 AM
calin's Avatar
calin
I've had this same problem a few times but with my RPM gauge. Not sure what the problem could be though.
Old Jan 17, 2010 | 10:51 PM
dirtbikr's Avatar
dirtbikr
sounds like a VSS if the digital one isn't working either... any SES light? usually it'll trip when a VSS goes bad, but not always.
Old Jan 18, 2010 | 01:33 AM
Nackers's Avatar
Nackers
I'm not sure what the VSS is.
But all my dummy lights are on because I've disabled pretty much everything. VSC, ABS, Airbag, and my SES light has been on for a long time cause the wires for my secondary o2 got pulled out on a bump or something.
I'll check the codes and see what I get. Thanks.
Old Jan 18, 2010 | 10:47 PM
dirtbikr's Avatar
dirtbikr
Then your Vehicle Speed Sensor is to blame. Replace it and you should have no more problems.
issyz
Jul 2, 2017 03:04 PM
HoBrahYouStink
Jun 24, 2016 10:58 PM
BOATS N HOES
Lighting
Oct 13, 2015 09:07 AM
SharX59
Sep 27, 2015 09:23 AM
