Trunk won't latch.
Old May 30, 2014 | 10:08 PM
allshownogo's Avatar
allshownogo
Thanks to the people that wrote up this DIY.
A few things I want to add onto the post:
1. be very careful when removing the plastic piece before getting to the actual metal frame, as those 4 metal-on-plastic clips that holds it in place can be easily broken.
2. before taking apart the small unit (the white box), try freeing the arm by moving it forward and backward.
3. if you do need to take the small unit apart, chances are, there is a weak tooth within the gears. I ended up just tearing off the semi-broken tooth and everything works like a charm.
also, based on looking at the pics posted, it's the same tooth in the gear that seems to jam up the mechanism.
took me about 30 minutes to take apart, fix, and put back everything together.
Old Jun 7, 2014 | 03:03 AM
omegamanuk's Avatar
omegamanuk
Thanks guys work great for me, the rubber grommet that limits travel looks like it gets worn and the quarter gear moves beyond its limit and jams, I cut a bit of eraser and put that in place of the rubber stop appears to have done the trick
Old Aug 13, 2014 | 07:08 PM
jbvalledorz33's Avatar
jbvalledorz33
This thread helped me greatly! I was able to take the gears apart and put back together with no trouble at all. Trunk now closes and opens better than before
Old Sep 3, 2014 | 02:07 PM
cynbun1's Avatar
cynbun1
Great thread! Thanks for all the advice and pictures were perfect, helped me figure out there was a missing piece, that was up underneath causing it to jam.
Old Nov 1, 2014 | 06:13 PM
JMC813's Avatar
JMC813
Man, am I happy I found this thread! Worked great. Thank you all for your inputs. I will say at one point when I was putting the plastic trim back on I stepped away from the car and the hatch slammed shut on the trim.. chipping the hole where it locks. If it's not one thing, it's another :-(. Oh well, I'll take a chipped piece of plastic if it means my trunk can stay shut!
Old Dec 10, 2014 | 12:09 PM
Persill's Avatar
Persill
Default Saved my day
I was ready to visit the dealership until i stumbled upon this. After hearing that it could cost a couple hundred dollars, i decided F*** that, and did it myself. My problem was that the trunk would not close or stay latched, so it would bumb up and down if i were to drive. Also when parked the trunk would not lock, hence ... granting overnight access to the inside of my car.
Thank you so much for this thread. It gave me the confidence to open the motor/actuator up myself, move around the cogs, and surely it was an easy fix I had no idea that this problem was so common. My trunk had been finicky since i bought the car a couple years ago and now its working better than ever.
Also TIP for everyone: That spring might be causing your problem. I had to pinch it to get the "arm" working again.
Thanks again!
Old Mar 20, 2015 | 08:55 AM
Louis21's Avatar
Louis21
Just adding my thanks to this thread. My 07 trunk decided to stop working while at work. Would not close just bump up n down. I thought I would have to spend a few hundred, not to mention drive back home 36 miles with a bumping trunk. Read this thread and while at work, took the thing apart. Turns out the spring was all the way stretched so when i opened the box and reassembled the gears it relieved the tension. Working great and saved me 300-400 bucks!!
Also thanks for the pictures made a big difference.
Old Mar 22, 2015 | 02:33 PM
ofish1112's Avatar
ofish1112
Default i need help from all of you
So my trunk button never worked and as of last week during my brake job my trunk started spazzing out and kept going off randomly every few seconds. So that has been going on for a week or so and now it doesn't work at all anymore and the trunk is stuck open. Help me! Suggestions?
Old Mar 23, 2015 | 03:55 AM
Louis21's Avatar
Louis21
I would try to remove the motor/actuator and check on it to make sure none of the teeth have jumped or like in my case that the spring is stuck in the stretched position. You've got nothing to lose and could save you a few hundred if it is something simple like that
Old Apr 19, 2015 | 02:42 PM
essejd's Avatar
essejd
Just used this guide to fix mine.
Same issue as everyone else with the broken tooth. Works well now.
Thanks all.
Old May 19, 2015 | 02:07 PM
yomike007's Avatar
yomike007
Originally Posted by muff-cabbage
Hey guys, first off thank y'all for the useful information. I just wanted to share this quick fix with you guys to avoid spending $200+.
I had a similar problem that yellow stealth had with a broken tooth on one of the gears. I cut and ground a thumb tac and pinned it into one of the lower rubber stoppers to shorten the gear pull before it reaches the broken tooth and it worked!
Sorry for the bad quality but heres how it came out.
Thanks for the tip! I had the same problem, broken tooth in the small gear. It was caused by the black stopper wearing down too much, causing the gear to overextend, which put too much pressure on the end teeth breaking them off. I just turned the black stopper sideways so its bigger section was stopping the gear. Took no time to fix.
Love these forums!
Old Jul 20, 2015 | 09:37 AM
sickZ31/Z33's Avatar
sickZ31/Z33
This thread has helped another Z member out, ME!.. This just happened yesterday to my 2008 Nismo, with 51k miles. Luckily nothing appeared to be broken in my actuator. I just realigned the gears in there, put it back together, and now it works just as good as it did before. Thanks!
Old Aug 27, 2015 | 07:21 PM
Davidian's Avatar
Davidian
Originally Posted by Yellow Stealth
I am resurrecting this thread to thank you for the write-up. My trunk latch acted up last night for the first time and I was able to fix it this morning following your instructions.
The removal process is pretty straightforward:
  • Remove or lift the trunk carpet and cardboard floor
  • Pull the trunk plastic liner center part up and out after disconnecting the trunk light connector
  • Remove the 6 big bolts holding the entire latch/actuator assembly
  • disconnect 2 electrical connectors as well as the trunk release cable so you can pull the entire latch/actuator assembly out of the car
Now the only part that confused me temporarily is that I expected the problem to be with the latch itself, but as you guys indicated, it is with the actuator/electrical unit. To open the actuator, you have to:
  • Remove two Phillips screws holding the actuator to the bracket
  • Disconnect the actuator rod from the latch mechanism
Now you can open the actuator by removing the 6 tiny screws. My particular problem seemed to be 2 of the teethed wheels that had somehow jumped from each other. Whatever your internal problem is, make sure that at the end the external lever can move freely.
Being in the San Francisco Bay Area, this thread just saved me at least $300.
Thanks again.
This totally saved my *** today. Got home and went to close the hatch and it just bounced up. Followed these instructions and in about 30 minutes it worked. Thanks a TON!
Old Aug 27, 2015 | 08:22 PM
Davidian's Avatar
Davidian
Ha! You too eh? I have the same mileage on my 2008 Nismo.
Old Sep 20, 2015 | 05:46 PM
cultcar's Avatar
cultcar
My 2008 Nismo with 89,000 miles just had the actuator fail. Opened, found no broken or worn parts, joggled it and verified full range of motion, reinstalled. Then 3 days later it's acting up again. I'm paying the $156 at Courtesy...
Old Sep 21, 2015 | 03:48 PM
Spike100's Avatar
Spike100
Same here. My actuator failed at about 100K miles. I removed it and everything looked OK. I reinstalled, and it failed again within a few days. I ordered and installed a new one. That solved the problem.
Old May 30, 2016 | 04:16 PM
Chico007's Avatar
Chico007
I'm thankful for this thread. My back hatch has been banging all week while my guy has been looking for an actuator ($150-$200). My '04 350Z has 185,000 miles and the hatch has finally stopped working (won't close). I stumbled upon this thread and a novice like me was able to fix it in about 45 minutes. I would not been able to do this without Yellow Stealth's pics and the ongoing confirmation from others.
This is how the quarter gear looked when I opened and removed the top gear.
I was able to easily move the gear to the proper position and put the top gear back on.
Old Jun 11, 2016 | 11:30 AM
  #38
Unicus's Avatar
Unicus
Bumping this for record and visibility. Having the issue now, will post pics if/when resolved. No socket wrench at the new house yet so have to get a set.
Old Jun 12, 2016 | 09:46 AM
  #39
Unicus's Avatar
Unicus
The EXACT same tooth is broken on mine, I will try a similar solution!
Old Jan 30, 2017 | 01:06 PM
  #40
Yellow Stealth's Avatar
Yellow Stealth
Thumbs up The thread that keeps on giving
So here I am 4 years later experiencing problems with my trunk that wouldn't latch again.
It's funny that I had to go back and find my own instructions in this thread to remember how to fix it. This time i do not have any broken teeth, but thanks to Chico007's pictures, I realized the quarter gear was stuck in the wrong position. I have now fixed it!
We'll see how long this fix lasts as my experience has found that a misbehaving gear tends to break down within months of the initial symptoms. Fingers crossed.
