Checking & Refilling Coolant Question
Old Feb 13, 2010 | 10:19 AM
xthejokerx's Avatar
xthejokerx
Default Checking & Refilling Coolant Question
Hi guys, i accidentally spilled some coolant and I want to refill them and have a few questions.
1.) If I want to reflush my coolant, where do I release the coolant from? I suppose I can't just unclamp the hose and dump out all the coolant right?
2.) How do I check the coolant level? On the coolant reservoir tank, there isn't an indicator regarding how much coolant is considered Full or Empty.
3.) Is it ok to add another brand of coolant to my existing coolant just to refill the spill without dumping all the old coolant out?
Thanks!
Old Feb 13, 2010 | 04:00 PM
DavesZ#3's Avatar
DavesZ#3
All your questions are answered in the Owners Manual in the Maintenance and Do-It-Yourself section under "Engine Cooling".
Don't have one? Download one here... CLICK HERE
Old Feb 18, 2010 | 02:38 PM
Vader007's Avatar
Vader007
There is a petcock on the driver side bottom just like any other rad.
There is a min / max line on the side of the reservoir.
Make sure you use Nissan coolant only or another HOAT antifreeze which is next to impossible to find in parts stores.
Be aware that there is a bleeder screw in the heater hose on the passenger side to help get the air out of the system after refil, make sure this is open when refilling.
Good luck!
issyz
Jul 2, 2017 03:04 PM
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
Sleeper_Z
Sep 30, 2015 10:25 AM
Li1ag
Sep 28, 2015 02:07 PM
SharX59
Sep 27, 2015 09:23 AM
