O2 sensors ripped/ destroyed... Is that ok?
Old Feb 24, 2010 | 04:23 PM
DozJr7's Avatar
DozJr7
Default O2 sensors ripped/ destroyed... Is that ok?
So turns out that the two o2 wires that connect to the test pipes are ripped, completely in half, severed. Like they got caught on something. Frankly I don't really care about the CEL since I know what it is from. This wont hinder any performance correct? The purpose for that sensor is just to tell you when your cats fail right? Nothing else..?
Old Feb 24, 2010 | 04:34 PM
KornerCarver's Avatar
KornerCarver
I Googled oxygen sensor purpose and found this:
O2 sensor
Every new car, and most cars produced after 1980, have an oxygen sensor. The sensor is part of the emissions control system and feeds data to the engine management computer. The goal of the sensor is to help the engine run as efficiently as possible and also to produce as few emissions as possible.
A gasoline engine burns gasoline in the presence of oxygen. It turns out that there is a particular ratio of air and gasoline that is "perfect," and that ratio is 14.7:1 (different fuels have different perfect ratios -- the ratio depends on the amount of hydrogen and carbon found in a given amount of fuel). If there is less air than this perfect ratio, then there will be fuel left over after combustion. This is called a rich mixture. Rich mixtures are bad because the unburned fuel creates pollution. If there is more air than this perfect ratio, then there is excess oxygen. This is called a lean mixture. A lean mixture tends to produce more nitrogen-oxide pollutants, and, in some cases, it can cause poor performance and even engine damage.
The oxygen sensor is positioned in the exhaust pipe and can detect rich and lean mixtures. The mechanism in most sensors involves a chemical reaction that generates a voltage. The engine's computer looks at the voltage to determine if the mixture is rich or lean, and adjusts the amount of fuel entering the engine accordingly.
The reason why the engine needs the oxygen sensor is because the amount of oxygen that the engine can pull in depends on all sorts of things, such as the altitude, the temperature of the air, the temperature of the engine, the barometric pressure, the load on the engine, etc.
When the oxygen sensor fails, the computer can no longer sense the air/fuel ratio, so it ends up guessing. Your car performs poorly and uses more fuel than it needs to.
It seems the oxygen sensor does more than just letting you know when your cats fail.
Old Feb 24, 2010 | 04:36 PM
0jiggy0's Avatar
0jiggy0
Post 2 is wrong, OP is right. Both REAR O2's as in the O2's after the cat are there to just let the ecu know the catalysts are working. Which yours werent anyway since you have TP's.
They dont affect performance at all.
Edit: after looking at post 2 that refers to O2's in general. If his front O2's were severed hed have major problems.
Old Feb 24, 2010 | 04:41 PM
DozJr7's Avatar
DozJr7
Alright good, I can sleep at night now... Thanks fellas.
Old Feb 24, 2010 | 04:43 PM
0jiggy0's Avatar
0jiggy0
if the wires are severed I would tape each one off seperatly. You dont want anything grounding out a feed from the ECU. That can be very bad.
Old Feb 24, 2010 | 04:47 PM
John Bronze's Avatar
John Bronze
Just repair the wires with some butt connectors.
Old Feb 24, 2010 | 04:49 PM
DozJr7's Avatar
DozJr7
Yeah I snipped the wires close to the connector plug on both sides and put a healthy dose of electrical tape to keep it from becoming exposed.
liqalu04
Jan 2, 2022 12:58 PM
2ndchanceZ
Oct 26, 2015 08:03 PM
350Z Project X
Oct 17, 2015 05:16 PM
