HELP!~ gas gauge fail
Old Mar 1, 2010 | 11:21 PM
aznvalli's Avatar
aznvalli
Default HELP!~ gas gauge fail
recently my gas gauge is not in working condition. i also try my friend's cluster and it still fail. even i have full tank of gas, it still shows that im have a empty tanks. anyone know what happened?
Old Mar 2, 2010 | 02:53 AM
Assume that the problem is the main fuel level sensor. Its a float that works similar to the float in a toilet tank.
Old Mar 2, 2010 | 07:31 AM
aznvalli's Avatar
aznvalli
can i change it from the top of the trunk or i need to drop the gas tank from the bottom?
Old Mar 2, 2010 | 11:04 AM
gyotar's Avatar
gyotar
I believe you can do it with the tank in the car. There's plenty of room behind the storage bins/sub plate.
Old Mar 2, 2010 | 11:16 AM
aznvalli's Avatar
aznvalli
thanks alot for all the help!~
Old Mar 5, 2010 | 02:25 AM
scoobyrex247's Avatar
scoobyrex247
did this fix up the problem. I'm having the same issue.
Old Mar 8, 2010 | 01:52 AM
Jeff_04z's Avatar
Jeff_04z
Default i have the same problem
i just drive 200 miles and fill my gas tank, but i would like to fix it. i think you need to order the hole pump which cost $300
liqalu04
Jan 2, 2022 12:58 PM
350Z_Al
Oct 29, 2020 07:44 PM
derekinthez
South East
Sep 28, 2015 06:35 PM
