Can a faulty APP sensor be linked to a P2135 code?
Old Mar 8, 2010 | 04:45 AM
skn5002's Avatar
skn5002
Default Can a faulty APP sensor be linked to a P2135 code?
I've replaced my throttle body, cleaned the maf, and rechecked the connections to the ecu. However, I am still getting the p2135 code once in a while. This leads me to think that maybe it is a bad accelerator pedal sensor. I am not getting a code directly for a faulty APP though. I am only getting the p2135 code. So could a bad APP cause a p2135 code or am I just wasting my money replacing it?
Old Mar 8, 2010 | 05:45 AM
Zazz93's Avatar
Zazz93
Definitely could, Here's a little bit from the FSM. Sorry but I copied and pasted them out of order but you should be able to get the picture.
Old Mar 8, 2010 | 09:14 AM
DavesZ#3's Avatar
DavesZ#3
After you replaced the throttle body, did you do all of the re-learn procedures?
Old Mar 8, 2010 | 12:28 PM
skn5002's Avatar
skn5002
Yes I've done the relearn a few times. The code seems to pop up out of no where.
Old Mar 8, 2010 | 12:32 PM
skn5002's Avatar
skn5002
Thanks Zazz! the FSM you posted really helped. Placed the order for the APP and hopefully it will be the solution
Old Nov 16, 2010 | 09:59 AM
zerosec's Avatar
zerosec
what was the result ? problem was solved by replacing the APP ?
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
Tochigi_236
Sep 27, 2015 03:40 PM
