Problems starting the car
Old Mar 11, 2010 | 03:50 PM
solidfish's Avatar
solidfish
Default Problems starting the car
I posted a few days ago about a dying battery that gave me some problems starting the car in the mornings. Well I got that fixed (battery was old/weak) but I still have my starting problem. Any suggestions would be much appreciated.
I'm no mechanic, but here's my deductive logical steps so far:
1. Engine cranks but does not start. After giving it a few (or several) more tries, it gets going. No odd noises during crank, no odd noises when running. No smells, smokes, CEL. All fluids topped. Climate here is mild at 60s everyday.
2. As my previous thread states, battery was weak and replaced. And it keeps its charge. So no problems with battery/alternator.
3. Spark plugs replaced. .
4. Starter cranks engine without problem and sounds healthy. Never hesitates, stalls, splutters. Just wont start.
5. There is fuel in the tank. :P
So I'm leaning towards fuel injectors/delivery system??? What do you think? Any other checks I can do to before taking it to the real mechanics?
thanks again
Old Mar 31, 2010 | 09:40 AM
350zHermosa's Avatar
350zHermosa
try your crank position sensors... I had the same problem about a month ago, that started out with my battery.. I drained it one night trying to get her to start for about 3 hours. Then changed that battery this worked for umm a day. Problem persisted for a month of so then was told by a bike mechanic to look into the crank position sensors, bought both for about $65 a piece at O'Reilly's, had my husband install them, and shes cranked right up ever since...
____________________________________________________________
STOCK '03 Track: ran a 13.2 1/4 mile. UGH, I need go faster!!
Old Mar 31, 2010 | 10:16 AM
Jarred@Z1's Avatar
Jarred@Z1
Z1 Motorsports
before you go buying stuff try a different key. sometimes the chips in the keys go bad and it wont crank it everytime.
Old Apr 1, 2010 | 03:11 PM
solidfish's Avatar
solidfish
Whoa seriously? Do you know what years the Z has chips in the key?
Otherwise, I'll look into the crank position sensor. But is there a way of diagnosing that as the fault?
Its really hard to replicate the problem as it happens so randomly. I thought maybe it was a cold start but I was at the bank the other day and stopped for no more than 10 minutes. Engine was still hot and it wouldn't start. After 3 or so tries it start and no problem. So odd...
lolwatbro
Oct 9, 2021 04:58 AM
pslamp32
Feb 8, 2017 09:07 AM
PureR3d
Sep 10, 2015 06:23 PM
Darkspy
Sep 7, 2015 09:09 PM
