'03Track Several Issues! *HELP* Please?
Old Mar 31, 2010 | 09:54 AM
350zHermosa's Avatar
350zHermosa
Default '03Track Several Issues! *HELP* Please?
1st- I had my AC line virtually cut in 2 by a crappy intake that was on it when I bought it. Replaced the intake and now I am wondering if anyone knows a $$$saver option to fix this AC issue, just recently moved to FL and it's a little hotter here than in TX. (my worry is my daughter getting too hot.)
2nd- Replaced the drivers side door 'shell'. (16 yr old ran into me a stop light) It was all cosmetic damage, but after putting the window back on and in track, interiors back together, wired back up and on the car, I am having a problem with my window not 'jumping' all the way up when I close me door, it will seal, but not like it's supposed to. Any suggestions?
3rd- After replacing the door, I am not able to pop the trunk with the LP button, I have to do it manually under the strut. The drivers side lock/unlock button will not register to the passenger side door. I have gone back over everything and am still missing the issue.. Ideas?
Thanks!!!
Amanda
_________________________________________________________
03' Track(stock):13.2 sec 1/4 mile..need more mods!
Old Mar 31, 2010 | 10:05 AM
huyrua's Avatar
huyrua
1st - buy a new ac line from and replacing it yourself. It's fairly easy. Then recharge it yourself. I had the same problem with my intake rubbing a hole into line.
2nd - Have you try the window rest button?
3 - I don't know (but can you post pics of yourself by the Z...LOL)
Old Mar 31, 2010 | 10:14 AM
350zHermosa
window rest button??
Old Mar 31, 2010 | 10:18 AM
Jarred@Z1's Avatar
Jarred@Z1
Z1 Motorsports
yeah pull off the door pannel and you will see a small black button on the center of the window motor. you have to close the door roll the window up the whole way hold the button and let it down then put it back up again and release teh button. i think its some manner of something like that.
Old Mar 31, 2010 | 10:32 AM
350zHermosa
I'll give that a try... Any ideas with the trunk release?
sherm
Apr 11, 2020 05:21 PM
350z82
Oct 1, 2015 06:25 PM
Depravity
Oct 1, 2015 04:49 PM
