Annoying click in clutch pedal!!
Old Apr 21, 2010 | 12:15 PM
AFD350Z's Avatar
AFD350Z
Default Annoying click in clutch pedal!!
O.k., simple complaint but annoying as sh*t when you're shifting through all your gears up and down all day..here goes...press clutch down either just low enough to shift gears OR to the boards, either way, 80 percent of the time on the way up it "pops" like your turn signal noise clicking..sometimes on the down AND up...6 gears..12 pops..wtf..
Took it to the dealer x 2 months ago, couldnt figure it out and they replace the whole clutch pedal..If i bring it back, sure its under warranty but it MAY happen again and i'll be without my car for 2 days because they're retards and thats what they want it for. Any ideas on what it might be?
I almost thought the actual pad on the pedal but..no dice..and i cant tell where its coming from on the assembly..
Old Apr 21, 2010 | 02:00 PM
SamSpicer's Avatar
SamSpicer
I have the same problem! I have no idea what it is though It only started doing it a few weeks ago but hasn't stopped since if first started. How many miles do you have and what year? 07 with almost 14k here
Old Apr 21, 2010 | 02:26 PM
JMSpeed's Avatar
JMSpeed
Some believe it is the spring getting stuck then popping back into place after it un-sticks.
I am taking it to my dealer in 2 weeks for the same problem among others.
Old Apr 21, 2010 | 02:29 PM
stogey420time's Avatar
stogey420time
Club Moderator
the Hot Spot
I have a HR with the same problem
Old Apr 21, 2010 | 02:48 PM
makopolo's Avatar
makopolo
Same problem here.....my solution....shift past 5k so i cant hear it. J/K
Old Apr 21, 2010 | 02:53 PM
TheOtherRob's Avatar
TheOtherRob
Same problem here also.
Old Apr 21, 2010 | 02:55 PM
AznSky's Avatar
AznSky
me too, i just deal with it by turning up the music when I can hear it over my exhaust
Old Apr 21, 2010 | 03:05 PM
AFD350Z's Avatar
AFD350Z
my car just hit 36k, was 32K when they'd replaced the whole pedal assembly..and it was fine til a week ago, i hear you guys on the music so i dont have to hear it but sometimes i just like to drive with no music on and hear the workings of the sexy *****...tomorrow's my last duty day at work then i'm spending some serious time investigating...
Old Apr 22, 2010 | 11:52 AM
AnhDepTrai's Avatar
AnhDepTrai
Try turning off you VDC IF you have it and see.
If thats not it and you don't have VDC.
Your **** out of loCks?
Old May 6, 2010 | 01:51 PM
Bevo's Avatar
Bevo
I have the same problem, please keep us updated.
Old May 6, 2010 | 03:05 PM
TheOtherRob
This had no affect to the noise...
Old May 7, 2010 | 11:46 AM
spacemn_spiff's Avatar
spacemn_spiff
Its the classic problem in my 05 too. The way I gather is the spring pops as you release the pedal. If you get under the dash with a flash light and press the pedal with your hand, you can see the spring pops as it rides on the pedal.
I just the grease the heck out of the spring in the clutch pedal assembly and it goes away. Its come back again and time to take a paint brush and grease it up.
Old May 10, 2010 | 10:31 AM
350Speed's Avatar
350Speed
I used WD-40 to spray on the spring, and it worked for me.
Old May 10, 2010 | 07:59 PM
LmFao's Avatar
LmFao
I just had mine replaced last week for the same problem, it was really annoying.
sherm
Apr 11, 2020 05:21 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
