Turn Signal & High Beam Indicators Don't Work On Dash
Old May 13, 2010 | 05:07 PM
hkbegun's Avatar
hkbegun
Default Turn Signal & High Beam Indicators Don't Work On Dash
Turn signals, hazards & high beams work, but none of the indicators work on the dash cluster. I have replaced all cluster bulbs and they work "on the bench" but not when plugged in. Upon testing the wiring harness to the cluster, it appears that there is no power going to the cluster. The cluster lights & gauges do work. Any ideas??
Old May 13, 2010 | 05:28 PM
AdvanZ33's Avatar
AdvanZ33
Senior Super Moderator
I was going to say AC module but the gauges didn't work when mine went out. Do any work on or around your radio lately?
Old May 13, 2010 | 10:07 PM
toner123's Avatar
toner123
not to sound obvious but did you check your fuses? If its not that sounds like a broken wire. you can grab a volt meter pull the fuse and read it out, if your getting power to the fuse box all your wireing under the hood is good and you have to start chasing from there. I had a issue like this in my truck and thats what i did, turned out to be a broken wire under the dash by the stearing wheel.
Old May 14, 2010 | 07:49 PM
hkbegun's Avatar
hkbegun
Yes, all fuses check out OK. Broken wire is possible, I will follow all I can. I am hoping someone knows of a relay or part of ECU that may be responsible. Thank you.
bcoffee20
Nov 19, 2015 06:39 PM
davidm350
Oct 31, 2015 02:28 PM
Shane86
Sep 17, 2015 05:33 PM
hardwood66
Sep 8, 2015 04:31 AM
Daniel_dh
Sep 7, 2015 12:56 PM
