Vibrations around 80 to 90 MPH
Old May 24, 2010 | 07:34 AM
burubuduy's Avatar
burubuduy
Default Vibrations around 80 to 90 MPH
I experienced this when reaching 80 - 90 MPH and I let off my gas pedal my car tends to vibrate but if I step on the gas it disappears. This only happens at around 80 - 90 MPH after I let off the gas and anything above that, it doesn't bother me. Any ideas as to why I'm experiencing this? Btw, I was driving interstate with a speed limit of 90.
Old May 24, 2010 | 08:05 AM
350junkie's Avatar
350junkie
if it doesn't bother you then how is it a problem?
Old May 24, 2010 | 08:40 AM
TreeFiddyZee's Avatar
TreeFiddyZee
Do WHAAAAT!?
Um. Where is there an interstate with a 90 mph speed limit?
Old May 24, 2010 | 09:15 AM
350junkie's Avatar
350junkie
i didn't want to say anything.
Old May 24, 2010 | 09:46 AM
armando325's Avatar
armando325
I had a problem kind of like that but it was when I went 60 the steering wheel would start vibrating, but it was due to unbalanced wheels.
Old May 24, 2010 | 09:56 AM
SexyRob's Avatar
SexyRob
I have a similar issue I've noticed... not sure what it is, I had my wheels balanced when I got the tires and everything was fine for a year then I noticed it starting happening after I took the front wheels off to check the brakes... I have since taken them off and reseated them multiple times, I guess I'll just need to get them rebalanced.
Old May 24, 2010 | 10:11 AM
bmccann101's Avatar
bmccann101
thats right where the rear end likes to howl... ( wait.. can i make a joke out of that?)
Seriously tho, i have solid rear diff bushings and while the vibration is now gone, thats where its the loudest, around 80 ish, freeway cruisng etc.
Vibration, well your rear bushing is prob shot... as is everyones really. And if not, its probably just another one. Check that first tho.
Old May 24, 2010 | 10:13 AM
SexyRob's Avatar
SexyRob
mine def. feels like the vibration is coming from the front end... how could a rear bushing cause this?
Old May 24, 2010 | 10:50 AM
adamc's Avatar
adamc
if its coming from the front then its most likely an out of balance wheel.. bad tire.. or alignment issue
Old Jun 25, 2010 | 03:25 AM
Synjn's Avatar
Synjn
Take off each wheel and check that the axl nut is tight. This is a common problem. And put loctight on all of them.
Old Jun 25, 2010 | 07:47 AM
winchman's Avatar
winchman
I don't think there are axle nuts on the front wheel hub assemblies.
TrboMike
North East
Sep 28, 2015 06:36 PM
CrowzRSA
Sep 21, 2015 04:00 PM
FromGtoZ
Sep 20, 2015 03:41 PM
T'S 350Z
Event Photos
13
Sep 17, 2015 12:55 AM
fst100
North East
Sep 8, 2015 11:37 AM
