A/C problem!!
Old May 26, 2010 | 10:50 AM
TheBlue350z's Avatar
TheBlue350z
Default A/C problem!!
my a/c all of a sudden stop working.. The heat works and all the fans speeds work as well, but it doesnt blow cold air.
I did notice that when i turn the a/c on i use to hear the clutch kick on when it use to work, but now i dont hear anything.
could i have a bad a/c compressor.. how much would that cost?
Old May 26, 2010 | 11:07 AM
Jarred@Z1's Avatar
Jarred@Z1
Z1 Motorsports
check for leaks first i doubt its your compressor your most likely out of freon.
Old May 26, 2010 | 11:53 AM
can'tZme's Avatar
can'tZme
++1
Old May 26, 2010 | 12:05 PM
blueVQ's Avatar
blueVQ
look at your belt and see if it came off. this is the issue i am having now as well
Old May 26, 2010 | 08:36 PM
winchman's Avatar
winchman
Clutches are really simple, and they rarely quit working. If you don't hear it engage when you turn the AC on, it's probably a relay, switch, or wiring.
Old May 27, 2010 | 06:03 AM
TheBlue350z
well i had 3pc pulley set installed, but i never checked to see if my a/c worked cuz it wasnt needed. all the pulleys are installed correctly and the belts are on there properly
i havent really used my a/c much since i got my car.. so do u think i would just need a a/c recharge to fix my problem. i only got 38k on my car
Old May 27, 2010 | 08:43 AM
Brett@AwesomeZ's Avatar
Brett@AwesomeZ
Vendor - Former Vendor
You should have a single wire that connects to the compressor to trigger the clutch, it could have been disconnected when you got your pullies done.
Uriyo_
Sep 8, 2021 08:46 AM
TDPrank
Sep 28, 2015 06:29 AM
