Drive Shaft knocking?
Old May 31, 2010 | 02:07 PM
Laurenx3's Avatar
Laurenx3
Default Drive Shaft knocking?
So recently my drive shaft shredded into two pieces out of no where. I got everything replaced and worked on by the Nissan dealer. Now there is a knocking noise that happens every so often.
If Nissan doesn't hear the noise, there isn't a problem.
Any ideas as to what it could be?
Old May 31, 2010 | 02:23 PM
dkmura's Avatar
dkmura
General & DIY Moderator
That's definitely not normal. The Z's carbonfiber driveshaft is precisely balanced and shouldn't be out of balance anywhere. Try to figure out when and why the knocking happens and get it back to the dealer before your warranty is up. The driveshafts in these cars have not been problematic, so it's definitely something on your car.
Old May 31, 2010 | 02:44 PM
Laurenx3's Avatar
Laurenx3
Unhappy
I keep taking it back to them, but since they can't get the car to make the noise they can't do anything. I get everything serviced when needed so I have no idea why this is happening.
It started doing when I was sitting still, but now it happens when I'm driving.
I def. don't want to keep it if somethings going to go horribly wrong after the warranty is done.
Old May 31, 2010 | 03:13 PM
350junkie's Avatar
350junkie
That is not the drive shaft then. Is the car a manual? Maybe it's the motor making a little noise?
Old May 31, 2010 | 03:14 PM
drivessidewayz's Avatar
drivessidewayz
^^What he said...perhaps it's the clutch/flywheel bs that everyone hears?
What are you doing when it knocks?
Old May 31, 2010 | 03:19 PM
Laurenx3's Avatar
Laurenx3
Sadly, it's an automatic.
I'm either going about 40-50mph or slowing down/stopped when it's knocking.
0jiggy0's Avatar
0jiggy0
How the fukc did your driveshaft shatter into 2 pieces?
Old May 31, 2010 | 03:20 PM
Laurenx3's Avatar
Laurenx3
I have no clue! I was taking off at a light and it snapped! Nissan doesn't know how it happened either. There have only been 7, including mine, reported cases of this happening.
Old May 31, 2010 | 03:21 PM
Barnabas's Avatar
Barnabas
National Z Club President
Lauren what kinda knocking does it sound like and from where?? Maybe the LSD got messed up when the drive shaft snapped??
BTW I destroyed my phone this weekend text me so I can get your number again.
Old May 31, 2010 | 03:27 PM
Laurenx3's Avatar
Laurenx3
Like the noise when you would knock on a door, but only louder? Under me, sometimes towards the front and sometimes from the back.
Old May 31, 2010 | 03:39 PM
350ZTheStandard's Avatar
350ZTheStandard
DId the stealership replace the u joint when the replaced the drive shaft???
Old May 31, 2010 | 03:45 PM
Laurenx3's Avatar
Laurenx3
I'm pretty sure they did.
But it's going back to the shop again this week, so I can double check.
Old May 31, 2010 | 03:49 PM
350ZTheStandard
Good idea, u can take a look at the bill also. I have to wonder if they forgot to tighten everything up. Still having a hard time believing your CF driveshaft just snapped under normal driving.
Old May 31, 2010 | 03:50 PM
Barnabas's Avatar
Barnabas
It was crazy when I saw it. She is pretty much 100% stock too. I couldnt believe it was snapped. It was just straight ripped in half.
Old May 31, 2010 | 03:56 PM
Laurenx3's Avatar
Laurenx3
It was replaced.
Everything from the back housing of the transmission to the u joint was replaced.
Old May 31, 2010 | 05:03 PM
drivessidewayz
out of curiosity...how much is a driveshaft from Nissan? lol. You sure it's all together correct/tight and there are no spare pieces of your driveshaft lodged between things?
I would keep this driveshaft cuz that's awesome >.< lol...in a way
Old May 31, 2010 | 05:20 PM
Laurenx3's Avatar
Laurenx3
A brand new drive shaft is like $900.
Nissan has the drive shaft, I wasn't allowed to keep it.
Old May 31, 2010 | 06:07 PM
Guilty1s's Avatar
Guilty1s
If it did it when your car was still, it isn't your drive shaft. Drive shaft only moves when the rear wheels move.
Old May 31, 2010 | 06:12 PM
Laurenx3's Avatar
Laurenx3
Oh. Then I have no idea what the noise is
It only started happening when the drive shaft broke.
Old Jun 3, 2010 | 04:46 PM
phreaktor's Avatar
phreaktor
Design Engineer
The violent acceleration of a stock 5AT Z is enough to do it.
